2025 Si full digital cluster works in 22-24 and here's what you need to get it done!
ayospoonay
Josh
Orlando
2022 PWP Si
Old cluster must be installed to "clone" then install new one to rewrite.
Shankmeyster
Shankmeyster
AZ
23 Type R
Like was said before, the easiest way to get this done with the smallest amount of dealer work is to have the dash already apart and ready to pull the original cluster so they can program the new one and they, or you, can plug in the new one once they are done.
I can understand people want to spend as little money as possible but this is NOT a cheap swap regardless. If you want it done right then there is a limit.
Johaw
2023 Civic si
I plan on getting the steering wheel out to swap buttons get dash apart go to dealer have them reprogram and re assemble dash in the lot
Johaw
2023 Civic si
New buttons and harness installed hopefully i can find time for the dealer this week at some point and finish this up
11th Gen Honda Civic 2025 Si full digital cluster works in 22-24 and here's what you need to get it done! IMG_9489
11th Gen Honda Civic 2025 Si full digital cluster works in 22-24 and here's what you need to get it done! IMG_9491
Shankmeyster
Shankmeyster
AZ
23 Type R
Add your sig #3
Rizzy4magic
Ricardo
Civic SI
Hopefully I will become number four when the parts arrive
Shankmeyster
Shankmeyster
AZ
23 Type R
That's if you beat Johaw to the install.
Shankmeyster
Shankmeyster
AZ
23 Type R
Now you must become one with the cluster swap crew.
