23' Si Tuning Questions
Crisspy
Cris
New Jersey
Honda Civic Si 2023
So I understand the concept of Tuning but i never had the opportunity to tune a car. I plan on getting a 27won DP for my 23 Si, it already has a K&N intake. I plan on also getting the intercooler at some point. But anyways, i still use this car to commute to work, im not looking to milk every bit of horsepower from the car, i just want a tune to be able to run the mods smoothly. Would i be better off going for a custom tune, or does something like the hondata pro have a tune i can simply take, that would work for me? I guess a more conservative tune, and in the case i get a CEL after the DP install, will the tune remove that? Not really worried about warranty, if i take it to a tuner, im assuming they would fix whatever issues i encounter post tune. (Correct me if im wrong). But like i said i just want a simple tune to have my mods run properly, i need this car to last, I don't plan on changing my driving habits, i average about 36-39 mpg, i only take this car through backroads maybe like once a week where i really push it, and by pushing it i mean going like 75 in narrow roads lmfaoo I don't do highway pulls nor do I intend to. So let me know what you guys have to say.
uwg55
Montreal, Canada
Civic SI 2023
Ktuner and Hondata both have tunes that comes with them, but I highly recommend that you take a look at the tunes from TSP and Phearable. I had tunes from both on my 10th gen and I really loved them!
As for going on custom tunes, sure that would be the best but it's the most expensive option. If you only have a downpipe, an intake and an intercooller I'd go for a OTS tune but if you have the money, go for it! The tuner will be able to really personalise the tune to your liking.
With ktuner you can disable the sensor to avoid getting the CEL. Pretty sure you can do it with hondata too but I don't have it so I can't really comment on that.
I highly doubt that. If any problems happens after a tune, you'll have to pay to get it fixed.
If you want to keep the car a long time, proper maintenance is the key. I think tuning is worth it from the experience I had with my 10th gen. I really liked the car better tuned. I plan to flash my new si but I don't know when I'll do it.
Crisspy
Cris
New Jersey
Honda Civic Si 2023
Really appreciate these answers!
lebadge
Tyler
Greenville, South Carolina
2023 Civic Si SGP
I recently did Ktuner/TSP Stage 1.
Like yourself i commute mainly, have spirited runs etc etc.
TSP recommends a PRL HVI Intake or OEM for their tunes, FYI.
Ktuner for sure you can disable the O2 if you get a CEL. Be on the look out for the non-code throwing DP from Two Stepper Performance.
IC/Charge pipes is highly recommended even if you don't throw a tune on it for heat soak issues.
City: 35MPG
Highway: 41-43MPG(sometimes more)
BCP
Barry
South Carolina
2022 Honda Civic SI
I recently did TSP Stage 1 tune on my 2022 Si. I disabled the secondary O2 sensor, but now I am getting emissions warning and rev match warning. Can anyone advise, please .
Shankmeyster
AZ
23 Type R
Why did you disable the 2nd O2? Are you running catless?
