265 or 275 tyres for TE37?
Sinner
Delaware
2024 FL5
275 is 100% the way to go. You won't rub at that offset even if you are lowered.
18x10 40 is about the equivalent in poke to an 18x9.5 35 correct? I’d think a 275 could be a gamble unless it ran very narrow
BigBird
yeah like running a 25mm spacer. this is less than than the 18x11 +44 that some run for track but with camber, so i'm sure it's fine with either size.
I'm running 18x 9.5 + 38's with 275/35/18's and zero issues. I also recently purchased a set of 18 x 11 +44's which I will likely have out on track in the next 4 weeks. The 18x11's poke, but hopefully no issues with rubbing on hard corners. @Rexpelagi also run's 18x11 +44's. Him and I are using the same tire size for the 11's, which is a 285/30/18. He is lowered, and I am not, so we shall see!
Shingo Shoji
Shingo Shoji
Jeremy
FL5 - Championship White
Thanks, that's incredibly useful. Looking forward to the change.
Shingo Shoji
Shingo Shoji
Jeremy
Thanks. I’ve gone for the V601 as well in 275/35/18. My matte black saga s plus wheels just arrived in country (18x9.5 +40) so only days to wait now.
Thanks for all the help. Based on the collective experience here and what I’ve read I’m hoping there will be no rubbing or poke.
Shingo Shoji
Shingo Shoji
Jeremy
Just sharing photos of the final fitment. Thanks to all for the advice.
Tiny bit of poke at the front from the beefy sidewall of the 601s. A slightly narrower 275 would probably be perfect. Doesn’t seem to bad to me but let me know if I should be worried as it’s my first step into aftermarket wheels.
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6376
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6412
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6420
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6418
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6404
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6417
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6374
11th Gen Honda Civic 265 or 275 tyres for TE37? IMG_6390
