Any issues with 275/35 R19 Tires?
TchnoZ33
Zaid
Indiana
Pretty much the title. Was thinking about fitting 275/35 R19 tires on the car. Stock suspension. Wanted to know if anyone has done this? Any rubbing? Should I stick to 265/35? Thanks!
FL5R-05967
Allan
CA
23 BB CTR, 93 NA Miata 72 Pontiac
You will be fine on stock suspension. Even with Eibach sportline springs you'll be fine. I'm running 275/35 R19 on 19x9.5 +43 on coilovers now to get a lil lower. No rubbing.
jdezee
Jack
sanford, FL
Curious on the responses here from those running that size. I was considering the same size I have 20mm spacers on all 4 corners.
FL5HondaGuy
Boston
2024 Championship White FL5
I am running 265/35/19 with H&R springs and H&R 20MM front and 25MM rear spacers with no issues. 275's are only .4 inches wider so I don't foresee a problem. There are a number of users here running 275 width tires.
11th Gen Honda Civic Any issues with 275/35 R19 Tires? FL5 Side Profile
raptor718
mid
How many finger gaps do you have? Pic? Thinking of doing same for that cushion.
Fl5#727
Oklahoma City
2023 civic type r
really debating or not to get 275’s also once my tires are worn out. almost there. I want to stay with 19’s and no springs or spacers, so i’m kinda hoping with the 35 side wall it will be a touch better ride and also being a 275 will help space it out a bit. does this mess with the speedometer or anything changing tire size?
i wonder if there are any 275/30/19’s out there they make?
FL5HondaGuy
Boston
You wont get much more poke at all as the stock offset buries the wheels. 275 is only @ .4 inches wider. You will reap the most benefit from the taller sidewall giving you more peace of mind and improved side profile (aesthetically speaking) .
See below for differences for
265/30/19
vs.
275/35/19
Tire 1
265/30R19​
Tire 2
275/35R19​
Difference​
Tire Height (Diameter)
25.3 in​
642 mm​
26.6 in​
675 mm​
5.22%​
Wheel Size
19 in​
483 mm​
19 in​
483 mm​
0.00%​
Sidewall Height
3.1 in​
80 mm​
3.8 in​
96 mm​
21.07%​
Tire Width
10.4 in​
265 mm​
10.8 in​
275 mm​
3.77%​
Tire Circumference
79.4 in​
2,016 mm​
83.5 in​
2,121 mm​
5.22%​
Revolutions per Mile
798.4​
758.8​
4.96%​
Revolutions per Kilometer
496.1​
471.5​
4.96%​
Speedometer Difference:
Tire 1 (mph or km/h):
20​
40​
60​
80​
100​
120​
Tire 2 (mph or km/h):
21​
42​
63​
84​
105​
126​
Tw1stedlog1k
Massachusetts
Integra Type S
265/30/19
vs.
275/35/19
Tire 1
265/30R19​
Tire 2
275/35R19​
Difference​
25.3 in​
642 mm​
26.6 in​
675 mm​
5.22%​
Wheel Size
19 in​
483 mm​
19 in​
483 mm​
0.00%​
Sidewall Height
3.1 in​
80 mm​
3.8 in​
96 mm​
21.07%​
Tire Width
10.4 in​
265 mm​
10.8 in​
275 mm​
3.77%​
Tire Circumference
79.4 in​
2,016 mm​
83.5 in​
2,121 mm​
5.22%​
798.4​
758.8​
4.96%​
496.1​
471.5​
4.96%​
20​
40​
60​
80​
100​
120​
21​
42​
63​
84​
105​
126​
Would you mind sharing your alignment settings? I basically ran your setup and the car did rub under certain bumps.
FL5HondaGuy
Boston
To be clear I am running 265/35 not 275. I am also on spacers (20mm front/25mm rear). I am running stock alignment settings. I am on a mild drop with H&R's (no bump stop trimming needed). Wondering if it was your tire choice as sometimes they can vary (one brand is wider/taller than others) I am running a Michelin Pilot Sport 4 A/S as well. You can see my drop in the picture a couple posts up for reference.
Tw1stedlog1k
Massachusetts
Integra Type S
That explains it, I missed that detail on your tire width.
I was running 275/35 PS4S and getting slight rubbing on the other edges of the tire. This was on a 19x9.5 rear wheel with +35 offset.
Back to stock tires in the meantime but I'm be trying it again with a more aggressive alignment setting at the next changeover.
