Are these cars actually reliable?
CG13
Houston
2024 FL5 Civic Type R
Manufacturers generally recommend not pushing beyond 240–250°F for extended periods. The FL5 doesn't come equipped with a true oil temperature sensor the LogR app provides estimated values, but it's not a direct reading from the engine oil.
I've installed a proper engine oil temperature sensor on the return line from my oil cooler back to the engine. It shows a 70–80°F drop after the oil passes through my dual oil coolers, which makes sense. Obviously, airflow plays a big role if there’s a car in front blocking fresh air, temps will rise.
Based on that, while LogR isn't a true oil temp reading, I’d say it's pretty close. The large temperature delta is mostly due to my upgraded cooling setup. I've reached out to companies like Mobil and PWR, and they all echoed the same advice: start cooling down once you’re hitting 240–250°F.
That said, I’ve pushed the car past 290°F (stock) before without catastrophic issues, but I wouldn’t recommend doing that regularly if you care about engine longevity.
Now, maybe we should let the OP define what reliability means to him. If you're chasing ultimate reliability, get a Miata, S2000, RSX-S — or better yet, a Prius. Turbo cars just won’t match the long-term durability of a well-engineered naturally aspirated setup.
Can you share the details on the gauge you’ve used for oil temps? What brand and how did you mount the gauge?
I am considering P3 gauge into my HEL oil cooler.
BuntaTypeR
I’ve got it mounted in my gauge with some double-sided tape. Just too lazy to snap a pic right now.
11th Gen Honda Civic Are these cars actually reliable? 1746228839257-fl
lilDumpsterRat
LA
Rs3, S3
Well fwiw, Mine had recurring issue with a high pressure fuel pump. and honda stepped up and bought it back from me for nearly what i paid. I bought another type R to replace it, and love the brand more than ever. They are the most stand up company I have ever dealt with.
SP R KiD
Matthew
2023 BB CTR, 2021 Toyota Highlander, 2001 F150
Definitely not how I was expecting this story to end haha. Your enthusiasm is compelling and surprising.
Either way, congrats! That's exactly how it should have played out. Hopefully you have a better experience with your new one.
