Back panel rattle from sound system
joerefunds
Ayer
IL
None
Hello all. ‘22 Civic Si with 1k miles. Ever since I got the car I’ve noticed that the back panel rattles where the sub is when playing songs? dealer said it was normal but i don’t have time right now to have them investigate. bass all the way up or down doesn’t matter. some songs rattle depending on the freq of the bass. luckily it doesn’t rattle when going over bumps. any tips or ideas?
also speaking of rattles.. it seems like when going over bumps (not playing
music) the B (i think?) pillar where the driver seatbelt comes out of, rattles on the highway / over bumps. and also where the dash cluster is right above the steering wheel. any tips for those?
thank you!
kev2069667
Kevin
Phoenix, AZ
2015 Civic EX Sedan
For the seat belt rattle from the b pillar I just moved the positioning all the way down and it stopped. I'm sure there's a better fix, but I'm still comfortable with the positioning all the way down.
For the rear dash sub rattle another user, idk if it was here or on the other forum, said they shoved some foam or a sock under the plastic from inside the trunk and it stopped.
HawaiiPunch
Will
Canada, GTA
2023 Elantra N
Yeah, I’ve shoved foam on a rattling piece of plastic before to stop resonating rattling. Just play a song that makes it rattle and find the piece, shove the foam in, and it’ll be fine. Maybe some double sided tape depending on where it is.
86salmon
It's Hedley, Hedley Lamarr!
SC
2018 Civic si sedan, 2001 Nissan Frontier
On my xgen, I ended up putting neoprene between the glass and rear deck panel after butyl sound deadener wasn't enough
i thought my rattle was the plastic surrounding the third brake light vibrating against the rear glass but it turned out be a plastic clip in the trunk. Just wiggled it around a bit and it stopped for now but I'm going to try and stuff some foam in there next time I have a day off work.
11th Gen Honda Civic Back panel rattle from sound system subrattl
also, anyone know why the sheet metal has ripples in it? Is that normal?
crash1340
Corie
Charlotte NC
2026 Civic Si
Why would it not be normal? That's far too consistent and uniform to be accidental. Those are stamped in to reinforce the metal. When it's flat it's flexible, but doing that adds strength.
