Mrjustin81
Doesn’t the stock intake only become a bottleneck once you get over the 500+ mark?
That’s why I’ll be going PWR when I upgrade the IC. It’s only 3lbs heavier than stock, cools extremely well, and doesn’t block nearly as much airflow to the radiator.
The dimensions of the COBB intercooler are nearly identical to the PWR unit.
getRIGHT
Looks like a solid option. Glad to see all these new FL5 products coming out. Hopefully it continues
Nope. Take any car making 400whp or more on a single inlet point intake (factory style opening only) and you can look forward to a 20WHP gain if you switch to a dual inlet style intake.
400 -> 420
450 -> 470
A reminder to some, this only shows its face if you dyno test with the hood closed, which is of course how we drive our vehicles.
Wow. Wonder why it weighs so much more.
Bar and plate vs less dense tube and fin
Edit: This is wrong! PWR's FK8 intercooler was tube and fin but the FL5 unit is noted as "lightweight bar and plate. 87mm thick utilizing our R-fin as the internal tube."
gerryman81
Austin, TX
2024 Civic Type R Sonic Grey Pearl
Got everything installed and test drove for a bit. Running the stage 2 Cobb map that goes along with the intake and intercooler. There is a stage 1+ map if you are just doing the intake too.
Some initial thoughts below. I'll drive it for the next week to get a better feel for the differences before the new parts
- Intake install was straightforward and easy
- Intercooler install was much tougher and is definitely a 2 person job. It was the first time I've taken the bumper off as well and took my time getting through all the pop out clips. The routing the charge pipes and hoses and getting them just right was the toughest part.
- Lots of turbo noises that I never heard from the stock intake
- Car feels a little quicker once it hits about 3k rpm and through the rev range but I'll be doing more testing on that
- I also did the acuity shifter bushings since thats all in the same intake/charge pipe area. Personally I don't feel like its a whole lot different then stock but I'm glad I did it
11th Gen Honda Civic Cobb Redline Intake and Intercooler Released PXL_20250906_201203949
11th Gen Honda Civic Cobb Redline Intake and Intercooler Released PXL_20250906_142855355
11th Gen Honda Civic Cobb Redline Intake and Intercooler Released PXL_20250906_201153384
JST Performance
Brian
East Dublin,GA
jst-performance.com
2024 Civic Type R, 2018 Civic FK7, 2009 Civic Si, 2005 Civic Si, 2015 Focus ST
I was hoping the intake could be run without tune... UGH
Yep, 100% have to. We tested this intake on stock MAF cal a while back and it definitely does not work. Its is a GREAT intake though. I was very impressed with the install and quality.
JST Performance
Brian
East Dublin,GA
jst-performance.com
Great intake and FMIC kit. Fit great on our test car, and will be getting a pretty hardcore shakedown next weekend at Gridlife Autobahn on our 500+whp FL5.
HuyR
Aaron
2025 Honda Civic Type R
There a intake call airtec very interesting to find out how it's compared to the competition out there
TheFactor
Factor
So Cal
2025 CW Civic Type R
400 -> 420
450 -> 470
I’m liking PRL HVI more and more every post 😆👍🏻👊🏻 I mean everyday.
Interestingly enough, PWR is bar and plate as well
This is correct! Thanks for the reminder. Their FK8 intercooler was tube and fine, my notes on their FL5 intercooler state "lightweight bar and plate. 87mm thick utilizing our R-fin as the internal tube."
