Dent door sill
MKC
Bay Area
Passenger dropped a water bottle and made a dent, I’m more than pissed…..
Easy fix by a dent pro?
11th Gen Honda Civic Dent door sill D473D4AE-D659-49B4-847A-44DC7EF18B7C
RP2000R
Dang wouldn’t think a water bottle would do that damage…
If a paint less dent guy can access behind the panel not a big deal. They may have to drill a access hole to smoothe it out then plug hole with a cap.
MKC
MKC
Bay Area
It’s a 22oz stainless steel water bottle fully filled up. Still that area seems very fragile….
The dent pro is gonna use glue tape to pull the dent out….. cost $230 ?
RP2000R
Ahhh that makes sense. Atleast it should be a easy fix. The newer cars just keep getting cheaper and cheaper quality imho.
Samurai1225
Chris
Cincinnati
Damn water bottle did that. I feel your pain. I have a tiny dent above my rear wheel arch which I assume was a car door slam. I haven't called a paint less company yet, but I won't sleep right until the dent is gone.
RUNN1N
You could throw an illuminated door sill on there and cover the dent entirely? If it's costing you $230 to have the dent (hopefully) removed, illuminated sills would be $300-$400.
This damage in that area can be done with less. I dropped my mobile phone and it dented the door sill with less than 100 miles on the car?. So annoyed. The phone slid off my leg, hit the sill, and then fell on the ground...dented door sill. I couldn't believe a dent could be caused by a relatively light weight object at close range. Anyhow, a good PDR outfit can pull this out for ~$300 without drilling or other invasive approaches. They can make access from the bottom of the car to pull it out. Good luck.
MKC
MKC
Bay Area
What the f a phone!how thin is the sill!?!
Did you pay a dent pro to fix it? Is it noticeable now?
MKC
MKC
Bay Area
The install seems a bit tedious
menikmati
STI, BRZ, FL5
The amount of force concentrated in a small area will do that.
I've had my phone fall face-down countless times over the years with no issue and it only took a 10mm socket from inches away to cause a crack.
MKC
MKC
Bay Area
my dent is right at the edge I don’t know if the accessory will cover it entirely
11th Gen Honda Civic Dent door sill 14921FA6-0F7D-47BD-8CD9-887169FE4542
11th Gen Honda Civic Dent door sill 7DE85346-0AB9-4A22-89A3-2F2783D9A06E
Yeah, lame, I know. A Samsung Galaxy S22 to be exact. It's only noticeable because I know it's there. Truth be told, I forgot about it until you started this thread. I had my PDR guy take a look at it and I just haven't gotten around to it. I'll have him take care of it at some point. Based on what I know about his work, it will be completely removed when he's done. He's taken out gnarlier dents with great success, so this is nothing.
Depends on your comfort level with installing these types of parts. They don't look particularly good so I would pass on that alone. I would just fix the dent and be mindful in the future sincethe aluminum in that spot is as soft as butter at room temperature.
MKC
MKC
Bay Area
They look tacky I agree. If the Type R logo is bigger and spread across the sill, I might look better but I’m not gonna pay $325 for that….
nttran98
Nhan
2026 FL5
To be fair to them, their hands are kinda forced.
Government want high efficiency average across the fleet ->popular model need high MPG -> reducing drag, power, and/or weight. And weight seems to be the way they went -> thinner panels and less insulation for noise
