How did you disconnect the pumped in sound? You take the grill off?Done it, hate the pump in sound. Worth taking it out. Or did you mean the volume auto adjusts? That I turned it to medium so not as noticeable since the fake pump in sound is out now.
I had to pull the vent. There's a screw there, you'll have to do it unless you got someone with small hands and can get in there and unplug it.I tried doing it without pulling the vent section and didn’t have any luck. Hoping someone can show us if it’s possible but I have up before doing any damage.
Thats huge, grats! I took it out to save 1lb and threw it awayHi there. Just got done disconnecting the active sound control module in my 2023 Honda Civic Type R FL5 11th Gen. I purchased the Orielly Auto Parts plastic pry bars/trim removal kit that I think that someone mentioned elsewhere. I did not have to take anything fully off except for the glove box. Everything else was removed enough for the connecting parts to be freed. I did not have to disconnect any wiring harnesses or clips. Took me about an hour but I approached detaching the vent panel very slowly. I used a zip tie to attach the hanging wire clip to the other part of the wire. See attached photos. Thanks for everyone’s advice on this.
Yeah, if you want to use +R mode (there are reasons for that, like tracking), then you have to live with the noise box or disconnect it. For most, Individual mode and setting the sound to Comfort, is quick and easy without risk of messing something up when taking the dash apart.So I never have to hear it.. and it's not that much work.
