Does It rub?: Fitment guide
CTRPR
JC
www.youtube.com
FL5 M3CS 4Runner
Hello everyone,
I wanted make a thread just so everyone can present their set up as info so other can get ideas and let us know if there are tire rubbing issues.
I know there is a fitment thread but I want to dedicate this one for wheel, tire and suspension specifics and discussing if the set up has good clearance without rubbing issues. If you had issues, let us know what modifications were done to fix the clearance issues.
Please include the following:
- Images
- Wheel specs: Diameter x width and offset
- tire specs + tire model
- Include spacer specs
- suspension specs with spring or coilover model (amount of drop id known)
- Camber specs if not stock geometry
- Does the set up has rubbing issues?
- if initially had rubbing issues, what did you do to fix the issue?
The Goal is to have as much information as possible accessible to the FL5 community since it is one of the most common questions out there.
I encourage everyone to post their set up, even though similar or same set up was presented, since we all enjoy just scrolling through pictures of the Type R ??
albi
Dallas, TX
TE37 Saga S-Plus - 18x9.5 +39
Michelin PS4S - 265/35/18
Swift sport springs - 25 mm
Camber - 1.7 front and 2.2 rear
No rubbing
11th Gen Honda Civic Does It rub?: Fitment guide FB_IMG_1681706286082
11th Gen Honda Civic Does It rub?: Fitment guide FB_IMG_1681706045868 -2
11th Gen Honda Civic Does It rub?: Fitment guide Civic XI (1)-2
11th Gen Honda Civic Does It rub?: Fitment guide Civic XI (2)-2
11th Gen Honda Civic Does It rub?: Fitment guide 20230408_164643-2 -2
tezzasaurusrex
Terence
No rubbing
Is that natural camber you've gained as a result of lowering or have you got camber arms/pins removed?
tezzasaurusrex
Terence
TE37SL 18x9.5 ET45
No spacers
RE71RS 275/35R18
Stock height (waiting for springs)
Camber
Fr -1.8°
Rr -1.5°
Factory suspension arms just with front strut pins removed and maxed out
Zero Rub
11th Gen Honda Civic Does It rub?: Fitment guide 20230425_191824
11th Gen Honda Civic Does It rub?: Fitment guide 2023-04-18__10.48.34
albi
Dallas, TX
No camber arms, just removed the pins. Front was 1.2 (left) and 1.6 (right) before removing pins and alignment; rear was 2.2, so no change in the back.
Geezer
Rob
Honda
Oem Forged
Bridgestone Potenza RE71RS 275/35/19
Stock suspension with front pins pulled 1.9 degree front camber
No rubbing
11th Gen Honda Civic Does It rub?: Fitment guide IMG_9794
11th Gen Honda Civic Does It rub?: Fitment guide IMG_9841
JDM_DOHC_SiR
Uncle Dave
Chula Vista
SSR GTX01 19x9.5 / 38mm offset
Nitto INVO 265/30/19
H&R Sport Springs -20mm down F&R
Front pins pulled and maxed out
Front camber -2.0°
Rear camber -2.0°
Zero rubbing
11th Gen Honda Civic Does It rub?: Fitment guide 39DCA0CC-A07E-45BB-870A-7A8CC8B8AD55
Kfo_cpa
Chicago
RDX
Oem Forged
No rubbing
I like. How do you like this compared to stock setup? Is the extra sidewall and lighter rims noticeable?
Geezer
Rob
Honda
The ride is definitely cushier with the extra sidewall. I only use these for autox so don't have a ton of other info beyond tons of grip with the re71rs. The re71rs in this size weighs significantly more than oem ps4s. I did weigh both setups on my bathroom scale oem/ps4s was 52.2 lbs and the forged/re71rs was 51.2 lbs.
