Does The Type R Intercooler Directly Bolt Onto Civic SI (Just Intercooler Itself)
CyberCT
Pennsylvania
2018 Civic SI Coupe,m 2026 Integra Aspec Tech 6-Speed
I'm wondering if the 11th gen Type R intercooler would directly replace the 11 gen SI's intercooler via direct bolt on replacement. Could be a cheap upgrade buying one used.
Has anyone tried this or know if it would fit?
marcusm86
Marcus
Missouri
2025 Civic Type-R
theres another forum if you search for it where someone has done this.
short answer is no - it does not just bolt up.
ModJPB
Jason
I did it. This site won't let me post a link to my writeup. It definitely helped with heat soak so you get consistent power.
It's not a bolt on fit, it requires some customization. Have to...
  1. Cut and bend the upper intercooler mount brackets.
  2. Grind two small notches in the typer intercooler plastic to fit behind the bumper reinforcement.
  3. Either use a cold side reducer coupler to the OEM charge pipes or buy the charge pipes by k&n (The PRL charge pipes are to big to fit the typer hoses over.)
You'll need Typer intercooler with both the oem end pipe connections and cold side rubber hose.
CyberCT
Pennsylvania
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
Just avoid the hassle and install the PRL one as direct bolt on, this is my suggestion you should not have any problems with warranty.
axion_industries
Chandler, AZ
Does not bolt up at all, the intercooler piping kit is 100% different
CyberCT
Pennsylvania
After doing some research and chatting with PRL, I'm going to agree with this recommendation
