FL5 (BS?) Autocross Thread
Sooner1
Adam
Kansas City
For you guys autocrossing on stock wheels and tires what pressures are you running?
I ran mine at 29-30ish psi cold since the track was super hot but that was here in FL.
Settled on 34psi when hot.
RacingManiac
Jen
Detroit, Michigan
2023 CW CTR R-12374
Nothing worse than breaking a stud at an event without having a back up. 😪
3 seized at Nationals back in 2019...had to go to O'reily's and buy some generic ones to swap out. At least FK8(and I hope FL5 too) you can get the studs in and out without taking the hub off...
Swapped all of the stud after the local later had more seized then I stopped using impact to torque/detorque them....
DustyDan
Dan
New Jersey
Just a FYI, Apex sells BS legal wheels and is having a huge sale right now.
I see them, unfortunately there is only one color and one size in stock that would work right now. Price is definitely enticing
RacingManiac
Jen
Detroit, Michigan
2023 CW CTR R-12374
Hopefully Apex does come out with something FL5 Type R specific eventually. The recent small group buy from Titan 7 I did jump on, but I also ordered something else too so I can get dailying set as well..
Sooner1
Adam
Kansas City
For track days I have Paragon P7 pads for the fronts. I am doing my first autocross in the FL5 Sunday. Thoughts on running stock front pads vs P7 for autocross?
RacingManiac
Jen
Detroit, Michigan
2023 CW CTR R-12374
I never messed with pads on my FK8, ran through I think 3 sets of stock Honda(Brembo) pads. No real complaints aside from being super dusty and wears pretty fast. Would be nice if there are less dusty option that doesn't sacrifice pad performance.
Thats with no tracking, I'd likely swap rotor and pads if I actually track this car...
simpleisbest
So. Cal
2023 CW CTR, 2023 Subaru BRZ
Stock pads work great for autox. Once I changed from Kumho V730s to RE71RS I found myself wanting a bit more threshold braking. I am currently using CSG CP pads and they are amazing! A bit more bite than stock, a wide window of modulation for trail braking, and stronger threshold braking. Plus they are quiet on the street with medium levels of dust.
Sooner1
Adam
Kansas City
First SCCA autocross this past weekend. This was my first AX event in the FL5 and I had only done 2 events previous and they were 25+ years ago. Car was completely stock on PS4s. I was registered in the novice class which had all novice regardless of car class and was ranked via PAX.
Car did amazingly well and in my opinion was very easy to drive quickly without getting out of control. I was a course worker in the first heat which is a huge advantage as you get to see where others are making mistakes. Used chalk on the sidewalls and ran 35 cold psi all around. Based on the chalk I did not make any tire pressure changes. Only had 4 runs and my times went from 56.9, 54.1, 52.7 and finally 51.975. The first runs were just figuring out what the car was capable of - there was defiantly time to be had with more experience.
I took first in the novice group which had 29 entrants including a CTS4 Blackwing, 22 GT500, and 2010 Jag XFR (also BS). Was 2nd in BS. First was a 23 GR Corolla on 200TW tires who had run it all last season. He ran a 49.924 to my 51.975. I thought 2 seconds back was pretty good considering my lack of experience and the tire difference. On a 50 sec course how much of a time difference will 200TW tires make??
I am signed up for event #2 next month and a 2 day HPDE event at Hedge Hollow (just south of Kansas City) in June. I have a GoPro (AKASO actually) on order so I will have video in the future.
Car did amazingly well and in my opinion was very easy to drive quickly without getting out of control. I was a course worker in the first heat which is a huge advantage as you get to see where others are making mistakes. Used chalk on the sidewalls and ran 35 cold psi all around. Based on the chalk I did not make any tire pressure changes. Only had 4 runs and my times went f 56.9, 54.1, 52.7 and finally 51.975. The first runs were just figuring out what the car was capable of - there was defiantly time to be had with more experience.
Tires make a big difference, with good. tires you will probably spank that Corolla.
DwightSchrute
Central Florida
2024 Type R, mk7 GTI, 15WRX
did you get any alignment at all?
Sooner1
Adam
Kansas City
No. Totally stock. Even though I plan on going to all the Kansas City SCCA autocross events this year I do not plan on doing anything with the alignment. In my opinion the car is pretty darty as is and at this point I don’t want to mess up how enjoyable the car is on the street. I do plan on getting another set of wheels (19ā€ - FL5 stock or FL5 forged) to run 200TW tires. I much prefer the look of 19ā€ to 18ā€ and don’t mind the ride on the 19s at all.
deadlyfishes
Matthew
Los Angeles, CA
matthewpablo.com
What's the p2w class we get bumped into with mods? STU? I really want the PRL HVI, and I'd have to swap it out every time I head out to AutoX... Maybe it's not so bad :D ....
I was in STH with my Focus ST because I had hella mods. Top 3 locally, but a ways off nationally. I like this car stock it feels great, but I am no stranger to mods, tunes, body upgrades for a bit of gains.
RacingManiac
Jen
Detroit, Michigan
2023 CW CTR R-12374
I think it would still be STU, thats where FK8 gets bump to. Probably unlikely to be terribly competitive.
Ran a really small lot local here last week, mainly to scrub in the RE71RS before going to a bigger site this coming weekend.
11th Gen Honda Civic FL5 (BS?) Autocross Thread 1715911394125-pa
This was the first time I ran with actual autoX tires and Karcepts rear bar on the FL5, the car feels kinda pogoing through places in corner on a not very bumpy lot. Played around with pedal dance mode to run softer suspension mode and didn't help much and made putting power down worse without the brake to supplement the LSD. Ended up 4th on Pax but I am plenty rusty and probably have easily another .5 sec in the car on a 34 sec course.
