SCCA Autocross GS Thread
EddieC2
Eddie
Norwalk CT
22 Civic Si Aegean Blue Metallic
I'm sure it is stiffer in general. I had read that the dampers were in between the two settings of the 10th gen's adjustable dampers.
It'll be intersting to see a head to head GS battle between the 10th and 11th. You seem to be doing quite well. Are you going to Nats?
I like the new Si but not enough to upgrade especially in this insane market. The interior is nicer but the styling is blander, especially the front, and there isn't a coupe.
Yeah I agree, If I had a 10th gen I probably would have kept it but when I bought it back in December to replace my totaled ST the used 10th gens were going for more then I paid for this thing.
And thanks! No I’m not, I’ve actually never been to a national event. I do pretty good locally but when I go to the bigger events like NNJR and NER I usually end up mid-pack for GS, but I am getting better!
BORAX46
Drew
Chicago
Focus rs
There is one 11th gen signed up, I think with two drivers. Hopefully they do well!
sackofcheese
sackofcheese
Andrew
Central KY
Decent outing today, handily took the class win but couldn’t manage a top 10 pax. Need to work on not overdriving the car
11th Gen Honda Civic SCCA Autocross GS Thread F034E16A-F502-4B2C-B90D-F4F076708D5E
sackofcheese
sackofcheese
Andrew
Central KY
Another Autocross is in the books. I was the only car in class, and we had a torrential downpour right before my 3rd run. Still managed 13th in PAX. Here is video from one of the wet runs
sackofcheese
sackofcheese
Andrew
Central KY
Last Autocross of the year for me is in the books. Took the class win and top 5 PAX.
11th Gen Honda Civic SCCA Autocross GS Thread 9F5CD07E-38EC-4F91-9DD8-B63C82188B03
11th Gen Honda Civic SCCA Autocross GS Thread 403EC721-B216-487F-B06F-CD7543D97DB4
11th Gen Honda Civic SCCA Autocross GS Thread EC316B7B-3C05-4210-AB9D-EE9E8027B7A8
sackofcheese
sackofcheese
Andrew
Central KY
With the local Autocross season officially over, I am quite happy with how my under prepared FE1 preformed. I took the GS class championship, and more importantly to me, scored my first ever Top 10 Driver of the Year! I can't wait to see how it stacks up next year with at least one of my local competitors getting a FL5, as well as installing new Potenza RE71RS in 255/40/18 and an bigger rear sway.
alhounos
Oregon
Congrats! You obviously know how to drive.
I used to autocross my old Miata. I'd love to get the Si out in the cones next season. Looking forward to hearing what some prep does for the car.
I was able to do a track day this year and decided a rear swaybar is needed. I'd imagine it would be even more beneficial on lower speed, tight autocross courses.
Balefire
Chicago
2023 Acura Integra, 2017 Subaru BRZ, 1993 Mazda RX
Is the 11th gen civic still competitive in GS?
My daughter has a small interest in making her Acura Integra Aspec competitive in GS.
We already have an exhaust, wheels, tires, and alignment.
Are any OEM camber bolts available?
What RSB are you guys running?
Anyone try a FSB?
Are koni yellows needed or is the OEM adjustable shocks ok?
I presume the PRL resonator plug is illegal?
Thanks!
Dazzling2394
I'd be curious if anyone else has insight - I can't find any front camber options for 11th gen, other than coilovers :(
sackofcheese
sackofcheese
Andrew
Central KY
Anyone try a FSB?
Thanks!
The 11th gen wont be as competitive as the 17-19 Si Coupes just due to the bad gearing change made for MY20. However with that said it can still be super competitive regionally and even at larger events with a Driver Mod. I wasn't running a rear sway but was looking at either the Karcepts or Whiteline 10th gen Type R bar since they are a direct bolt in. I also ran on the OE Si shocks, so I would wager the Integra ones would be more than capable. also that resonator plug would be illegal.
However my Si has since been replaced by a FK8.
SlowAP2
Terry
FL
25 CTR
So then there are front camber options for the 11th si, but would it be legal in GS?
It would not be legal. You can pull the front pins and that will gain a couple tenths of a degree and that is it.
You will need to go to STH to get proper camber
Dazzling2394
Womp, like @SlowAP2 said, it would not. Org I am classing in for track days has same point cost for ball joints + sway bar upgrade, so I thought of them as interchangeable.
