FL5 tire rotation
MKC
Bay Area
Which one is the proper way to rotate tires on a FL5?
At what mileage do you do your first rotation?
How often afterwards?
11th Gen Honda Civic FL5 tire rotation IMG_3408
11th Gen Honda Civic FL5 tire rotation IMG_3409
GV27
Alon
Israel
FL5 type r
The manual calls for the cross method. I periodically check the tread depth and when there’s a difference of 1-2 mm I’ll rotate them.
Nothing
2023 CW FL5 #5044
Do as the manual states, but usually for fwd it is either. I've always just done front to back on fwd during 5k oil changes (maintenance minder), but if your route has a lot of turns in one direction or one side is out of alignment, then maybe cross would be beneficial (but I'd want to see that in the tire wear and fix the toe). If you have directional tires front to back only.
