Funky sound when shifting from first to second
BigChungus86
Hamza
New Jersey
Civic type r 2024
just after 25,000 miles my fl5 started to make an odd sound specifically when shifting from first to second. I am not sure what is causing it. I took it to my Honda dealership and they said they couldn’t replicate the sound(as usual), and that they checked the transmission and there is nothing wrong with it. I am now starting to notice some other slightly higher pitched sounds at low rpms, almost like whistling. Could my turbo be going out? I am fbo with a phearable stage 2 tune. Where is this sound coming from? Turbo? Transmission?
Are you referring to that “pew” noise just as the shifter starts into second gear? I have the same noise under the same condition. I doubt it’s anything to worry about, though I don’t know for sure. Probably the second gear syncro doing its thing.
just make believe that every time you hear it, you’re shooting down an alien spacecraft with your laser gun!
BigChungus86
Hamza
New Jersey
Civic type r 2024
Are you also fbo? I just don’t want to have my turbo blow or something. When did your car start making that noise? How would I go diagnosing this sound?
BigChungus86
Hamza
New Jersey
Civic type r 2024
And yes I am referring to the pew sound close to the end of the video clip.
edido
CA
DE5
I have DE5, and also have the same pew sound when shifting from 1–>2nd only. I asked in Integra forums, but didn’t get ideas from members. It started around 14k miles. I don’t have crazy mods, most bolt ons. I have a tune - I can try to flash original map but I think it’s not related to the tune.
I plan to visit my dealer, but will probably end up with the same result “we couldn’t reproduce it.” Hope someone here can help.
Amm5890
Andrew
2024 CW CIVIC TYPE R - #17038
have the same pew sound. Sounds cool as hell.
I have a downpipe and intake plus a tune that’s probably very similar to yours.
I actually hadn’t noticed the sound until I listened for it this morning. I’m pretty sure it’s transmission related. Short of having an expert transmission repair person hear it, I doubt a regular tech at Honda is going to be able to tell you much.
Again, I don’t think I’d worry about it unless it gets worse.
FL5ghost
Charles
Tampa
2023 civic type r
I have the same sound as well with a whine between 2/3K rpm. It’s normal I’m FBO on E50 running the RV6 AS turbo.
sam3r_11
GTA, CANADA
Type R
did you end up figuring out what this was?
sam3r_11
GTA, CANADA
Type R
did you end up figuring anything about this sound?
Deleted User 3888
Sounds like a gear spinning another gear but was faced with a hair of resistance for a second? My type s doesn’t do that. But I only have like 2600 miles
sam3r_11
GTA, CANADA
Type R
i have 26k kms on it and it just started. I went away for a week on vacation so the car sat for 2 or 3 weeks. it's also really cold here but i drove it last year in the cold and didn't have this issue. i still have warranty so thinking to take it in
Deleted User 3888
It’s faint but for that brief moment when U can hear it. It reminds me of the straight cut gear sound. Almost.
