How to check tire pressure on FL5?
ewcg0100
wayne
los angeles
Hi guys,
Does any option to check the tire pressure data on FL5? Or just the warning light shows up when happens.
2023 CTR #3177
Warning light only, you'll need to use a manual gauge to get the actual #s. The upside is there is no TPMS sensor to deal with when you change wheels or tires.
Yep exactly. TPMS is great until you have more than one set of wheels/tires. I think it’s smart they didn’t put TPMS on the FL5 with track days (and likelihood of an alternate wheel/tire set) in mind. It’s also helpful for folks who have a winter setup. Just check your tire pressures periodically…the same with checking the oil. It takes 5 mins and you get the pleasure of being more familiar with those aspects your car.
Isn't there a TPMS though? I think people said that its like motion based or something like that, also doesnt the system have to do with the irregular shaped valve stems?
It has TPMS that is based on rotational speed. It doesn’t tell you how much air is in your tires, though. That’s what I think most people refer to when they say they wish the car had TPMS. This is also the reason you’re supposed to reset/recalibrate the FL5’s TPMS any time you air up the tires (unlike other types of TPMS that sense the tire pressure).
2023 CTR #3177
Exactly. The system we have is great because it "just works" but it can't tell you what the pressures are or even if it's too high or too low. It's basically just an idiot light.
The newest full fat TPMS can show exact pressures at each wheel which would be great for track work, the downside is the cost of the sensor & that they use batteries.
I'm cheap and have a tire pressure gauge so I'm fine with our setup :D
madbikes
SF Bay Area
FL5's TPMS is based on wheel speed sensor readouts. This type of system is not sensitive enough to quickly let you know there is a flat tire with a sudden loss of tire pressure. However, that is awesome for people who has winter wheels or swap wheels like changing shoes often.
I was a little short of dodging a big rock and cut a tire on my FL5. TPMS did not tell me I have a flat.
That’s pretty crazy. You’d think at minimum it’d detect a flat and set off a warning light.
keller
Somewhere south
2019 fc3, 2021 fk8
It also only works in straight sections of roads. In a curvy road it will ignore all readings until you get to a long straight section.
Nah, no excuse for not having active TMPS. All my prior cars had it, and no big deal when changing tires/wheels. ITS has it.
OK. Then how did you deal with resetting the TPMS sensors when changing wheels/tires? In my prior car I’d have to take it to a shop and recalibrate every time. Because that’s a pain, I decided to just ignore the TPMS on my winter set and the incessant beeping (for about a week until it stopped). I also had to ignore the constant TPMS warning light. I figured I should be checking my tires more often in the winter anyway…but, it would’ve been nice to have TPMS working if there was a simple solution as you suggest.
urbo73
All my wheels/tires had sensors. Nothing to do really.
Right. All my wheels/tires had sensors too. The problem is that the TPMS system in the car could only calibrate to 1 set of sensors at a time. So to calibrate to my winter set, I’d have to go to the shop. Then when spring came along, I’d have to go back to the shop again to calibrate back to my spring/summer wheel/tire setup. The FL5’s TPMS “lite” system, negates these complications…which I guess you’ve never experienced?
urbo73
I've had passive TMPS in my cars 15+ years ago or even more. Every car since has had active TPMS, and 0 issues "recalibrating" it when swapping wheels. BMW, Porsche, etc. This is a step backwards, to save money. Nothing more.
Ah OK. Doing some reading, Honda put an Indirect TPMS system in the FL5 vs Direct TPMS. Indeed Direct is better (and likely more expensive). The biggest issue with Indirect TPMS is that it might not detect a low tire if all tires are similarly low. Additionally, they don’t seem to be as sensitive in general.
https://www.tirereview.com/indirect-tpms-imports/
What’s weird is that my 09 Si apparently had Direct TPMS. Though older and crude by today’s standards, it definitely worked…but a pain when swapping settups.
The takeaway : Check your tires periodically. It takes 5 minutes.
