Icehawk's "OEM+" speaker upgrade
Icehawk
Icehawk
2023 CTR #3177 (stolen)
@Icehawk can you clarify a bit for me.
I am only seeing an ES-6 option, not an ES-6.2. Are these two different speakers, just want to make sure i grab the right ones.
Use the link actingbusy posted above and scroll a good way down and you’ll see two different sets of 2ohm speakers. I would opt for the less expensive ES as, with stock power and DSP, I doubt you’d see much difference for the extra $ on the model up.
Have no fear of refurbished, I have bought like 6 sets or more and they all look and function as new.
11thgensiguy
Teamh0nd@
2022 si 2000 ex
Excellent thank you ! How has the stock amplifier held up with the 1 ohm sub ?
Icehawk
Icehawk
No issue, it’s what it is designed for. I have the bass turned up a few clicks, more than that and it’s overwhelming (from a SQ POV, it’s still a 8” driver so only has so much depth and performance).
Mikity
Chicago, IL
2023 CIVIC TYPE R
@Icehawk and @actingbusy
For the rear CDT ES-5 5.25 speakers, do I also need that ring adaptor to fit properly and wiring harness/adapters ?
Or would it be a direct fit, no ring adaptor needed ?
actingbusy
Eric
Houston
2024 Honda Civic Hatchback Touring
You can optionally use the same size speakers as the front, just look for a 4 ohm rating for the rears and yes, you do need the adapter rings and speaker harness if you dont want to cut into factory wiring.
Mikity
Chicago, IL
2023 CIVIC TYPE R
Sweet! I'm most probably going to go that route then.
11thgensiguy
Teamh0nd@
2022 si 2000 ex
Thank you for all the hard leg work. I have an si and am discovering just how bad these bose speakers are. The fronts have barely worked since ive owned the car, I'd have to pop of the liner and wiggle whatever wire that is that is hot glued to the cone to get them to temporarily work. The sub is blown, which to be fair, I do have a part to play in that failure.
One last question sorry to bother, do you happen to remember what baffle you got to go in the door panel to help protect from water draining thru the door?
Did you cut a hole in the bottom to port the baffle ?
Icehawk
Icehawk
I didn't baffle the fronts and my installer didn't end up using them in the rear either. If you are going to do it I'd probably just cut them in half and just cover the top and not worry too much about it, stock there isn't anything so I guess Honda figures it'll be fine for a few years at least :D
mattfeet
2024 CW CTR
Can someone let me know what adapter ring and harness I need for the front tweeters and rear door speakers, please?
furyousgeorge
SoCal
2025 FL5 Type R
What did you have to do to the factory harness to wire it up? Could you share a photo if you have it? Or did you spice away from harness and wire straight to speaker?
Ok update as speaker arrived.
I wanted to make the box more solid so I used a layer of Killmat. Get it all wired up and had to make some new holes to drill in the screws for the sub. Added just a little killmat in the trunk areas as a precaution. I mean less than 5 sheets so not much weight. Here is how it turned out .
furyousgeorge
SoCal
2025 FL5 Type R
Thanks for sharing your experience @Icehawk
Just got done updating the fronts following your advice and it's quite a noticeable improvement.
Went with the DRT-25s. Cut a small slit in the A-pillar mounting ring to give some room to expand and the new tweeter squeezed right in. Secured with hot glue for now; may revisit with epoxy in the future if it doesn't hold in the FL heat. For the tweeter wiring, I cut plug off of the stock tweeter and soldered up a pigtail with the cap inline on the positive wire.
Getting the A-pillar off was ezpz following this
Will be ordering a set for the rears this week and at least put some matting on the stock sub box.
Did you ever get the Recoil sub installed?
Did you install the inline frequency filters?
