DeVo
Austin, TX
Do it the fix is pretty simple. This solved it for me.
I don't think this is it. I did the first step when I first got the car and that screw in the 3rd step was tight on mine. When I put pressure on the infotainment the rattle stops
Yeah the screen housing is very creaky. You’d have to remove it from the car (which I’ve seen a video of somewhere) then mess with adding damping materials inside.
Bazgab
Rob
Raleigh, NC
My car developed a really annoying buzzing on the front passenger side after exhaust + RMM install. I originally couldn't determine if it was coming from the door or B Pillar and it has been getting stronger over time. Sometimes it would happen on the driver side front as well, but rarely.
It was the seatbelt retractors down by the floor, underneath the B pillar trim. Seems like a common issue in 11th gen Civics in general. Here is what I did:
  • Removed lower B pillar trim
  • Unbolted the 10mm bolt that attaches the mounting bracket for the retractor to the chassis
  • Put some sound deadening material behind between the chassis and the bracket
  • Reattached retractor bracket to chassis with 10mm bolt.
  • Put some sound deadening on the white plastic housing that is attached to the retractor.
  • Put trim back together
Probably took 10 minutes total and the buzzing is now completely gone. I only have one more consistently occurring rattle now in the center dash or up by the map light, it is hard to tell. I have already put foam tape and sound deadening material in both these locations but I must have missed something.
Finally figured out the rattle “clink” sound (when hitting a bump) occasionally coming from the trunk area after like 18 months of ownership. I did EVERYTHING I could think of to locate and eliminate the issue…except 1 fairly obvious thing! The “clink” was coming from the trunk latch! There wasn’t enough tension in the latch, so basically my trunk door was bouncing just a little bit and the latch would “clink” like two chain links being snapped tight against each other. I couldn’t replicate it except when driving, so I had ruled out that it was an issue with my trunk and thought it was probably a loose heat shield under the car. I was very wrong. To fix it, all I had to do was move these rubber bump stops down (located on both sides of the trunk door).:doh:
11th Gen Honda Civic Interior noises - rattles, creaks, squeaks! imag
Motpeds
Pedro
Chicago
FL5 - CW
NICE! I will give this a shot later today.
I had the same issue and couldn't figure out how to stop it.
I settled on wrapping the latch with some electrical tape to provide more tension. Worked great, but after about 1.5 months, the tape it gets all cut up and requires replacement,
Imped
Indianapolis
MK7.5 Golf R, ND2 Miata
This is the single most annoying car I've ever owned when it comes to NVH, specifically N & V. Since day one, I've been battling noises, rattles and clunks. Maybe one day I will actually be 100% happy with this car, but I kind of doubt it.
TX
The interior rattle, which I assumed was in the center speaker/navi area, was the plastic surrounding the mirror's base. As another member stated, pushing up resolved my rattle.
Stanleywinthrop
Usa
10th gen
Had a bit of a revelation today. I've had an annoying rattle from the area of my drivers door for several months. Today I finally broke down and took the panel off to try to find the source. After much searching, i finally figured out the door harness connector to the exterior door handle (the smart key sensor) was hanging loose inside and could easily be the cause of my noise. It does have a clip to attach it to the door that would make it snug, but the clip was detached for some reason, probably from the factory as I had never accessed that area.
To be clear the harness was attached to the handle so my keys worked fine, but simply hanging loose. Weirdly there was a second clip attached to the hole where the harness connector clip is supposed to go. I guess someone at the factory was asleep that day.
I am talking about the black connector inside the door connecting to the exterior door handle. You have to peel back the upper left portion of the door liner to access this area. If your window is down you won't be able to reach it.
DavidHC
David
EU
Honda Civic
I had similar rattles. I added felt tape around the metal pieces that those bolts screwed into. They look like the item circled in green. There were more in the direction of the blue arrow. It sounded like this before:
Did you have bolts in those holes originally? I have two of these metal pieces with a hole and no bolts inside. Are they missing because they forgot to add them or is it normal that they are not there?
i've noticed a rattle in the engine bay. I think it's coming from one of the plastic brackets/clips on the firewall. top-center. Anyone else have that? particularly noticeable on rough roads.
FiveSeven108
Orange County, CA
2025 CCW FL5
anyone have a "ticking" noise coming from the drivers side b pillar? I have it at idle and driving on smooth surfaces. it would say its there about 30-40% of the time. its pretty annoying since its right in my ear.
Likely the common seatbelt “buzz.” I’ve found that all I need to do is push down on the seat belt height adjuster (so the mechanism sits more tightly in the housing) and the buzz goes away. I might have to do it again several months later, which is fine compared to it buzzing almost every time I drive. Others have taken more drastic measures, putting damping material in the columns.
FiveSeven108
Orange County, CA
2025 CCW FL5
Apparently mine is caused by the shiny trim piece on the outside of the car, its intermittent depending on how it is outside. I drove my car at night yesterday and no sound. I'm going to have honda replace the trim piece for me. (part number 72470-T24-T01) I hope this helps anyone else that may have a "ticking" noise.
