Jester’s Hondata thread
jtlctr
Jake
Great turnout!
jtlctr
Jake
Some of the results from a couple of the cars done.
FBO FK8 stock turbo/canflex
FBO FL5 stock turbo, canflex
Wow! Is the FK8 making more hp/torque over the FL5 because of a higher ethanol content, or are the turbos that different?
How much ethanol were they running?
AspecR
Stefan
The Fk8 stock turbo is actually bigger than the FL5 turbo, the FL5 will spool slightly quicker but all things remaining the same the the FK8 will make more power.
The FK8 turbo is slightly larger than the FL5 turbo.
The FL5 is a more efficient turbo in the sense of that it makes almost just as much while being smaller but up too it does drop a bit more compared to the FK8 one.
The FK8 had more fuel so was able to run a bit more ethanol but after a certain point it no longer matters, you can reach mbt timing with a pretty low % mix.
TypeRVA
Neal
Richmond, VA
2024 Honda Civic Type R
I gotta get this ice out of here and my Hondata straight! Need more!
kekoa_t808
Marcus
HI
25' Civic Type R
FL5 with kuro+, left it there because that is what the customer wanted. Plenty more on tap if needed.
The other two graphs you mentioned can flex. What about this FL5 tune with the kuro+, Is this also FBO plus canflex?
The other two graphs you mentioned can flex. What about this FL5 tune with the kuro+, Is this also FBO plus can flex?
This is fbo, fuel system and canflex and the kuro+. Car had easily another 40-50whp available, just left it there since the customer did not want to push a stock engine too far.
TypeRVA
Neal
Richmond, VA
I guess I finally get to jump in on this thread. I have been talking to Javier for like a year, but I just finished getting the car ready thanks to the realest @PointByPatrol. @Jester04 has been awesome to work with and has the car running great on 93. We will be moving on to ethanol pretty soon. If you are nervous about remote tuning, don't be...it's been an incredibly easy process.
Zone47
Joe
NE Ohio
Any Jailbreak events coming to Ohio this year?
Hondata is the one currently doing jailbreak tours. Right now I can do shipping ecu or if there is enough interest in the area, 10 plus cars then it can be scheduled.
Zone47
Joe
NE Ohio
I can make a run to Columbus (I think that is where they met before)... I'll have to see what their schedule is. Thanks.
Phukincruzin1510
Las Vegas
25 MBP Type S
Getting jailbroken on the 14th and hopefully tuned by jester immediately afterwards, pretty excited. @Jester04 sent you a DM on the integra side but will continue the convo here if its easier..
