Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights.
CivicSportSGP
NA
Honda Civic, Mazda CX-5
This is an initial "review" of the Lasfit T3 7443. In just 600+ miles, these are the second set of LED turn signals I have installed in this car. So far, they worked as advertised. Though I doubt these are "4000" Lumens. I prefer the design of this bulb over their previous attempt at a "resistor-free" LED. And if Type R owners are using Lasfit, I don't see why my plebian FL2 can't.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240505_152650
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240505_163648
https://www.amazon.com/LASFIT-Signal-Extremely-Resistor-Standard/dp/B0C8M81CY1
If I'm honest, I have a big disdain for Lasfit, stemming back to my 10th gen days. They tend to "buy" influencers by sending free product and make up absurd specs. No matter what, replacement LED bulbs cannot make 13000 lumens. Especially if the headlight or foglight housing is not designed for it. For more information about this topic, please see these threads in Tacoma World.
https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
https://www.tacomaworld.com/threads/why-leds-should-not-be-run-in-halogen-reflectors.454371/
For that reason, I used bulbs from either Diode Dynamics or VLEDS, or brands used by professional headlight builders. When my FL2 first arrived, I replaced the turn signals with the GTR Lighting i-LEDs that, too, were installed in my FC2.
After a few days, I replaced the reverse lights with VLEDS V6 Tritons, bulbs I used in my FC2 and my old Focus. I tried to do it a the same time as the turn signals, but when following the instructions, the base of the bulb was either too small or, using the included adapter collar, too big to fit in the opening. After some help from VLEDS, I was able to make them work. Coverage and output were amazing and felt as if you had headlights in the rear.
https://www.vleds.com/v6-triton-extreme-kit-w-921.html
You may be reading the title wondering why I mentioned the above. Well, after four days, the combination of the VLEDS and i-LED caused two fuses on the BCM to pop, and "bricked" my FL2 with 168 miles on the odometer. Thinking this was something else, I limped the car to my nearest Honda dealer, only for them to say the cause of my issue was these bulbs. As a result, I ended paying for a hefty diagnostic fee and was charged $40+ for four incandescent bulbs. Though, after this happened, I noticed the nut holding the positive terminal was loose and at the end of the bolt. I tightend it down and talked to the service manager, who mentioned that one of the techs may have disconnected the battery for a hard reset.
Long-story short, instead beefy bulbs with heat sinks, I just went with direct replacements. The XPRs, while not as bright as the VLEDS, still utilize the reflectors in the housing well. However, since there's a tiny heatsink at the tip of the bulb, there's no light going forward.
https://www.diodedynamics.com/921-xpr-cool-white-backup-led-bulbs.html
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240430_171605
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240430_175034
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240430_230141
I'll update this thread to see if I experience the same failure as last time. And include a night shot of the Lasfit bulbs. Though the XPRs have been in my car for almost a week.
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
Very strange that the positive terminal was loose. Pretty sure all service instructions would tell the tech to disconnect the negative terminal.
Thanks for sharing your experiences otherwise.
FL5CW
North America
If they performed a battery reset, both terminals would have come off.
CivicSportSGP
CivicSportSGP
NA
As promised, here's a video at night of the Lasfit bulbs in action.
They're much brighter than stock. But, unsurprisingly, not as bright as the i-LED. Please note I left all the video settings on my phone on auto.
I didn't notice for about a week until I decided to look under the hood. Negative terminal was fine. I felt something was off when I blew the horn fuse trying to i stall the Euro horns. I assume the tech failed to tightend down the positive terminal. It's possible I'm not going back to that dealer again in the future.
I have reached out to VLEDS regarding the V6 Tritons. They said the could test my bulbs to see if there were any issues. The 921 base adapters checked out, as did one bulb, with a healthy 0.93 amps. The second bulb failed to power on. I can't be sure if the bulb failing caused too much resistantnce in the circuit. Or if the the bulb failed after the fuses popped.
CivicSportSGP
CivicSportSGP
NA
Update on the XPRs. So far, my FL2 is unscathed. I can confidently say that this combination works on the Civic. However, one bulb has popped off the same socket, twice! For the first occurrence, I bent the metal prongs on the bulb outwards, so it sits snug. That lasted more than a week. The second time, I bent the prongs in the socket inward, in addition to the bulb. Hopefully this is the last time it happens.
CivicSportSGP
CivicSportSGP
NA
Here's a surprising update. After a few months, I have replaced the XPRs with VLEDS High Output 921.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 1000005334
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 1000005338
https://www.vleds.com/shop-bulb-numbers/921-led/921-6-ho-w-5k.html
Not because the bulbs failed. But with surprising regularity, the driver's side bulb kept falling out of the socket at least once a month. I was sick and tired of having to fish out the a bulb from the housing. Unlike an incandescent 921, these don't clip into the housing (though I think that applies to all LED 921 replacements). Combined with a heavy base, the bulb slips out over time. I've tried bending the tabs on both the socket and bulb, and applying dielectric grease, as recommended by Diode themselves. But to no avail.
The main reason why I returned to VLEDS is because one of their engineers has the same bulbs in their personal FL5. Plus they have an option for 5000K bulbs, which I went with. Though I haven't measured it, it feels as if the bulb is lighter at the base versus the XPRs. Below is a comparison.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 1000005333
Regarding specs, raw output is 1500 lumens, before stabilizing to 850LM. For comparison, the XPRs have a raw output of 1600 lumens, stabilizing to 720 lumens. It's too early to judge, but when weather permits, I'll update with photos.
CivicSportSGP
CivicSportSGP
NA
Here's a photo of the VLEDS HO 921 in action. There's more dead zones in the light pattern. It's not really a surprise since these are two-sided bulbs versus the four sides of the XPR. But brightness is comparable. I tried to park a similar distance to the outhouse, though I overshot it by a lot.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20240730_225949
CBP.FL5
Alex
'25 Civic Type R
Reviving this thread - how did the XPRs fit compared to Lasfit? I am dealing with the same issue of the driver side rear turn signal falling out.
CivicSportSGP
CivicSportSGP
NA
If I'm honest, the XPR is just too heavy for the Civic's socket. It slotted in fine, but would slip out in a few weeks.
The lighter (no pun intended) VLEDS HO-Six fit the best and provided similar performance, in my eyes. Not once did it fall off.
Though I've since moved on and moved back to GTR Lighting, but for the reverse lights.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20251217_171615
Unlike the VLEDS V6 Extreme I installed the first time, these are universal pressure fit. Due to the weird "in-between" size of the socket, the gasket leaves some gaps when installed.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20251217_173724
For the price, this fitment is less than ideal. However, I can't complain about performance.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20251217_181607
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 20251217_181735
I haven’t popped fuses with this setup.
Long-story-short, for your case, I recommend the HO-Six from VLEDS, but wait for a sale.
https://www.vleds.com/shop-bulb-numbers/921-led/921-6-ho-w-6k.html
pneutin
Bay Area, CA
FL5 Civic Type R
What do you recommend for turn signal replacements? I don't need the absolute brightest -- I just want LEDs that don't fall out. Will the VLEDS V6 Triton fit well?
I found that turn signal LEDs that just use a heat sink end up hyper flashing due to overheating. I would recommend getting any of the LEDs that have a built in fan, I found that I haven't had any hyper flashing with those.
This is what I'm using currently, no hyper flashing and they don't fall out, they used to be a lot cheaper than they are now, but there are cheaper similar options.
https://a.co/d/01xpFO0n
CivicSportSGP
CivicSportSGP
NA
Depends on the body style. I can't speak for the sedan, but the V6 Triton fits fine behind the taillights on the hatchback. Of course, I used heatshrink and dielectric grease to protect the socket.
11th Gen Honda Civic Lasfit LED turn signals + Diode Dynamics XPR Reverse Lights. 2809
I had these lying around from my 10th-gen.
The Lasfit worked fine for the month I had them installed. Though I can't vouch their longevity.
pneutin
Bay Area, CA
FL5 Civic Type R
I have an FL5 so it sounds like it should fit. But @Chilly613 's comment about the heatsink designs eventually hyperflashing, is kind of discouraging. 😅 Did you experience that with the the V6 Triton in particular?
Thats a different type of bulb set up, not something I would use myself or would spend that type of money for a turn signal bulb, but to each their own.
CivicSportSGP
CivicSportSGP
NA
No hyperflashing on the V6 Triton Extreme. Can't speak for the V6 Triton.
All I say is try Chilly613's set first and see if it meets your needs.
