Looking for 2022+ Civic Si OEM Fog Light Installation Help
Hazardous3
Hazardous3
Pennsylvania
2022 Civic Si (Blazing Orange), 2016 370z Nismo
My local dealer helped me find the part numbers today.
FOGLIGHT LEFT FR. - 33950-T20-A01
FOGLIGHT RIGHT FR. - 33900-T20-A01
SWITCH ASSY. - 35255-T20-C11
iundeadlich
Brandon
South Carolina
2018 Honda Civic Type R
Does the switch assembly come with wiring as well like the fog light kit on ebay? OR is it just the switch?
Hazardous3
Hazardous3
Pennsylvania
Tomorrow I'll ask my dealer about it. And will report back. If it ends up not including the wiring harness, I'll see if I can get a part number for that.
As far as I know I think it's just the headlight stalk switch
iundeadlich
Brandon
South Carolina
Dealer informed formed me that the wiring harness would be built into the engine's wiring. As seen in this image for a 2022 Civic Touring. I asked if they could look up parts for Canadian 2022 Si model vehicle; unfortunately said they couldn't.
32200-T22-A40 WIRING HARNESS, ENGINE ROOM, part is $489.72
Hondapartsnow sells the same wire harness for $296.36 as of 2/08/2022
However I did reach out to OpenRoad Honda Richmond in Canada about a fog light kit for a 2022 Civic Si. Hoping to get at least more info. We might be stuck with going third party for instance sellers on ebay. But if you want OEM factory install. We'd be looking at a very expensive setup.
At this point I'd just buy the fog light kit off ebay and just replace the fog lights that came with the kit with a OEM pair. Or look for a wiring harness that's separate from the engine wiring harness.
11th Gen Honda Civic Looking for 2022+ Civic Si OEM Fog Light Installation Help 20220208_074217
Shankmeyster
AZ
23 Si
Has anyone checked the part numbers on the harness for the trim that has fogs against the ones that don't to see if it's just a plug and play? Some manufacturers use one wiring harness across the board and just tie off wires/connectors they don't use on certain trims.
iundeadlich
Brandon
South Carolina
Today I happened to go to another dealer nearby. And got the parts list for a USA 2022 Civic Si. This dealer informed that the wires are probably on the harness themselves. But I'd have to look to verify that. They said that Honda like to interchange parts inbetween different vehicals.
32200-T22-A00 WIRE HARNESS, ENGINE ROOM, part is $471.47
Hondapartsnow lists it for $330.97 as of 2/08/2022
When I get time sometime next week hopefully, I'll take a look inside to my engine bay to see if I can find the wires for the fog lights. Though I am expecting to not see any connections for the fog lights.
11th Gen Honda Civic Looking for 2022+ Civic Si OEM Fog Light Installation Help 20220208_165504
Shankmeyster
AZ
23 Si
Just check the wire harness part number between your car and one that has fogs from the factory. It's easy to do online.
