Make PRL HVI installation easier
xpeng
I did the installation today. Found out some tricks.
So don’t reinstall ECU until the end, and don’t install the bolt to the second air intake duct until you connect it to the main case.
without the ECU you will have enough room to connect the pipes easily.
Also the clamp on the filter is too small, I had to buy a 6-7 inches one from HD.
