neildrives
neildrives
Neil
Bay Area, CA
2023 CW FL5 Type R #8960
New wing! Voltex Type 2 1600mm.
Also forgot to mention I installed the MXP Comp RS Exhaust + front pipe. Slightly louder than stock when you do the fuse mod.
Car is dirty, please don't look too hard 😁
11th Gen Honda Civic neilisnext's FL5 Build Thread Q1000324
11th Gen Honda Civic neilisnext's FL5 Build Thread Q1000304
11th Gen Honda Civic neilisnext's FL5 Build Thread Q1000315
neildrives
neildrives
Neil
Bay Area, CA
Installed Ohlins R&T DFV Coilovers on my car.
Not sure if I'll keep these long term, the drop is about ~0.8.5-0.9 inches all around, which is about maxing how low the Ohlins can go before the spring doesn't have preload.
Currently at the middle setting, 10 clicks from stiff. The dampers are great over large, immediate bumps in the road but it's quite bouncy running them this low. I've got to experiment running them softer to see if that fixes things.
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01444
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01477
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01462
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01449
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01435
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01476
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01460
Wendy's the
The bold portion above is a curious statement, along with already posting them for sale with the thought of going in a different direction. What's the issue with this setup and which other direction do you plan to take the car?
neildrives
neildrives
Neil
Bay Area, CA
Couple things:
  1. Ride height which is probably no surprise. Running these low make the car quite bouncier than I expected over smaller bumps.
  2. Electronic damper control. Turns out I do like having that feature
Planning to either switch to RS-R's active coilovers or just going back to Swift Springs + ITS module. I would like to stay on the route of changing out the system because the dampers are better than factory even with the ITS module but RS-R's are backordered for a while :)
I would’ve spent more time dialing them in before moving on from them, especially considering the quality of the R&T product offering. A lot of what you described sounds more setup-related than an inherent issue with the suspension itself. Ride height, alignment, damping settings, tire setup, and preload will completely change how the car behaves.
That said, I think you clarified priorities. You clearly value OEM adaptive damping behavior and daily drivability more than chasing maximum chassis performance, which is totally fair. I just don’t think the Öhlins setup ever really got the opportunity to show what it’s capable of when properly sorted.
neildrives
neildrives
Neil
Bay Area, CA
Some updates:
My CLEiB Wing arrived from Garage IMMI. I think it sets off the car much nicer than the Voltex Type 2 did when paired with my M&M Honda lip.
Also swapped over to RS-R coilovers. They fit my use case a lot better. They are everything I loved about running Swift Lowering springs but with better damping so I highly recommend.
If I tracked my car more, I'd be happy with the Ohlins but these are perfect. Here's some pics of both.
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01918
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01929
11th Gen Honda Civic neilisnext's FL5 Build Thread DSC01916
11th Gen Honda Civic neilisnext's FL5 Build Thread L1000314
11th Gen Honda Civic neilisnext's FL5 Build Thread L1000276
neildrives
neildrives
Neil
Bay Area, CA
Nothing new as of late, just liked these pics that I took earlier this week.
Still waiting for new wheels to arrive..
11th Gen Honda Civic neilisnext's FL5 Build Thread L1000378
11th Gen Honda Civic neilisnext's FL5 Build Thread L1000384
11th Gen Honda Civic neilisnext's FL5 Build Thread L1000368
