No Audio
Ohlins8990
IL
FL5, 3G MDX
Has anyone else encountered an issue where there is no radio output?
I commonly use Pandora through carplay for music. Today when I started the car it did its little boot up, but the audio never started playing. Tried adjusting volume, turning audio on/off, and changing source to FM with no luck. System bings/bongs still worked. I restarted the car at a stop light and audio returned. Is there a way to reboot the infotainment without restarting the whole car. So far this seems to be a one off event, but worried it will return more frequently.
katch922
Raf
2024 CTR
I have had that issue multiple times unfortunately, but mine has to do with apple auto/fm radio. I find restarting car main way to fix it.
Something I’ve tried that seems to help, I always start the car with my phone not hooked up to the usb wire, after my car connects to apple car play, then I connect my wire to my phone.
nawfoo
Banned
Banned
K
Lost Wages
Integra Si
If you turned off the car the day before and Pandora was working and not mess with your phones bluetooth or wifi it should connect automatically when you start it again. If it doesn't open up car play then you can put it into Comfort Mode real quick to reset the screen.
It sometimes likes it when you have your phone plugged in too.
