OEM Rims Winter Tires
87jkhockey
Josh
New York
Hello all, I am currently trying to find winter tires for my 2025 fl5. I read on forums that people have run 245/35R19 winter tire. However, all of the tire shops that I have talked to have told me to downsize to an 18 in wheel. I was wondering if anyone has had success with running winter tires on the OEM wheels without rubbing or if buying 18s is truly the best option?
coolnick
Nick
Cincinnati
2024 CW CTR
The problem is finding a true winter tire that fits the stock wheel. You also stand a higher risk of damage when you hit a blind pothole. I ended up ordering some Enkei 18x9.5 +45 wheels with Michelin Alpin 265/35 18s from tire rack and they have been fantastic so far.
2fast916
Jon
2025 Honda Civic Type R
I echo coolnick...
Very similar set up except I decided to try 255/35R18 Michelin Alpin PA4's
11th Gen Honda Civic OEM Rims Winter Tires IMG_3946
J_D
J
Montreal
I run a 255/35/19 Viking Contact 7. No issues in snow and pothole country up here in the great white north.
get the same size in the VikingContact 8
k20.dennis
dennis
2025 SGP FL5
I run 255/35/19 Pirelli Cinturato WeatherActive. No issues with fitment on stock wheels lowered on H&R springs.
11th Gen Honda Civic OEM Rims Winter Tires IMG_4208
coolnick
Nick
Cincinnati
2024 CW CTR
These cars rip in the winter a little salt won't spoil the fun.
2fast916
Jon
I echo coolnick...
Today was the day I decided winter may actually be in the air…
11th Gen Honda Civic OEM Rims Winter Tires IMG_4024
11th Gen Honda Civic OEM Rims Winter Tires IMG_4025
11th Gen Honda Civic OEM Rims Winter Tires IMG_4027
11th Gen Honda Civic OEM Rims Winter Tires IMG_4029
11th Gen Honda Civic OEM Rims Winter Tires IMG_4030
Spart
2025 Integra Type S
The only size of winter tire I find on TireRack in the OEM 265/30R19 size is the Michelin Pilot Alpin 5. They're quite expensive in that size at $400/tire.
255/35R19 has more options, but still spendy.
I would echo others regarding going to a different wheel. With a dedicated winter wheel, you just slap them on yourself rather than going to a tire shop 2x a year to give them an opportunity to scuff your wheels.
It wouldn't even be that much more expensive, considering a Bridgestone Blizzak WS90 in 235/40R18 is $256/tire. So if you can find wheels that are $144/ea, it's a wash.
The benefit of going narrower is that you'll have slightly better grip in snow and much better hydroplaning resistance. With as little as these cars weigh, a 265mm wide tire is going to make hydroplaning on slushy snow very easy. Going down in width to 235 or 225 is safer when you're in those conditions.
I posted my winter setup here: https://www.integraforums.com/forum/threads/winter-wheels-bbs-sr-18x8-44.58346/#post-938868
jcb
Jeff
FL5 Type R CW
Used Pilot Alpin 5's last winter. Great tire. Quiet. Not as sharp as a summer tire, but pretty good...and no worries in the very cold. On original wheels. OEM sized...perhaps the only tire you can get in 265-30-19 btw. Supposed to be far better than all seasons in snow....probably true but not a lot of snow last winter.
