Ohlins TTX fo FL5
SaVitar
bkk
My Öhlins TTX is now complete. The main body was produced in Sweden, and the peripheral components were completed by Öhlins in Asia. With 3-way adjustability, let’s continue to move forward with our passion.
11th Gen Honda Civic Ohlins TTX fo FL5 IMG_4153
11th Gen Honda Civic Ohlins TTX fo FL5 IMG_4148
11th Gen Honda Civic Ohlins TTX fo FL5 IMG_4149
11th Gen Honda Civic Ohlins TTX fo FL5 IMG_4150
SaVitar
SaVitar
bkk
They look beautiful, let me know how you like them. Still deciding on what coilovers to get.
This shock absorber system is being installed on my car.
SaVitar
SaVitar
bkk
Did you consider the option to use a true coilover for the rear vs the divorced setup?
Yes, I initially asked the team whether it was necessary to use an integrated structure. The team responded that it was not ideal; they recommended a separate structure instead. Although I don't know why, the team has extensive racing experience, so I decided to follow their advice.
sugarl4nd
Andre
Sugar Land, TX
2023 FL5 CW & 2021 FK8 LE Phoenix Yellow
Gosh, this is beautiful. How much is it and how long is the lead time to get the TTX ?
007
2023 GR Yaris - Circuit Pack
The real Ohlins. Beautiful.
Ordinary suspension systems simply cannot compare to remote canisters. Night and day difference. If you know, you know.
First proper FL5 suspension I’ve seen on this forum.
007
On most cars with a divorced suspension setup, switching to a true coilover rear setup typically requires reinforcing the shock tower. This reinforcement goes beyond just heavy-duty plates; it usually involves actual shock tower welding, often as part of a larger cage piping setup, like this:
11th Gen Honda Civic Ohlins TTX fo FL5 IMG_6811
Erroon
Connecticut, USA
2023 Honda Civic Type R - FL5
Hi @SaVitar are you able to share any information that could help the rest of us go for a similar build? (spring rates, part numbers, anything). How's the car doing 6 months later?
simpleisbest
So. Cal
2023 CW CTR, 2023 Subaru BRZ
Any pics of the fronts installed? Interested to see how those reservoirs are angled for clearance.
beamerciv
Jez
2020 Honda Civic
Those remote reservoirs look pretty sweet. I'm wondering where you ended up mounting them? Any issues with clearance or heat from the exhaust?
