OIL leak
North Carolina
2025 Honda Civic Type R
I believe I have a similar oil leak. I have a 2025 FL5 with 5.2k miles on the odometer. I took it to a local dealership and had the car inspected. They couldn't identify the exact leak location, but suspect it is the oil pan as well. It seems very similar to @k20.dennis situation with oil on the upper bolts leaking down to the main drain plug.
11th Gen Honda Civic OIL leak oil_leak
setsaki
Sekou
Fl5 type r
Yeah, more than likely its the oil pan
gakhar
BC
2008 Civic Si, 2025 Civic Type R
11th Gen Honda Civic OIL leak IMG_3412
Same issue for me at 1800 km, dealer resealed my oil pan so hopefully it holds. If it doesn’t they’ll move to ordering a new pan.
North Carolina
Update:
Dealer is saying that their field tech has never seen an issue like this before, and will not replace the pan until they just do a reseal. I do not want to open the bottom end of this motor twice if a reseal doesnt fix it. From what you guys are posting, its a casting issue, not a sealant issue.
gakhar
BC
Update:
Mine said the same citing not wanting to waste a good part, which seems fair. Only couple hundred kilometers since my reseal but its holding for now.
You could always agree to it and request the tech takes a look at the oil pan to see if the casting seems flat/smooth.
North Carolina
Gotcha, I authorized them to go ahead with the repair. I will keep you guys posted.
gakhar
BC
Just for reference if anyone else comes across this, I did my first oil change at 1000 kilometers and it was already seeping. Cleaned it up and then rechecked at 1800 and it was still seeping so they resealed and want to take a look in another 1000. So mine was an issue straight away.
I’ll also check back in when I have more kilometers on it.
North Carolina
My pan was clean at 700 miles when I did my first oil change, but had seepage at 4400 miles for the 2nd oil change, roughly 6 months after purchasing the car.
North Carolina
300 mile update is good news! I put the car onto the lift and could not find any oil. It was completely dry around the drain plug and bottom of the pan.
The leak was coming from between the rear motor mount and the exhaust. It seems like it is gone with a reseal of the pan.
I hope this holds, and if anyone else has this issue can get it fixed.
