OIL leak
ackermann_angle
2025 Honda Civic Type R, 1999 Honda Civic LX 5 Speed
I believe I have a similar oil leak. I have a 2025 FL5 with 5.2k miles on the odometer. I took it to a local dealership and had the car inspected. They couldn't identify the exact leak location, but suspect it is the oil pan as well. It seems very similar to @k20.dennis situation with oil on the upper bolts leaking down to the main drain plug.
11th Gen Honda Civic OIL leak oil_leak
setsaki
Sekou
Fl5 type r
Yeah, more than likely its the oil pan
gakhar
BC
2008 Civic Si, 2025 Civic Type R
11th Gen Honda Civic OIL leak IMG_3412
Same issue for me at 1800 km, dealer resealed my oil pan so hopefully it holds. If it doesn’t they’ll move to ordering a new pan.
ackermann_angle
Update:
Dealer is saying that their field tech has never seen an issue like this before, and will not replace the pan until they just do a reseal. I do not want to open the bottom end of this motor twice if a reseal doesnt fix it. From what you guys are posting, its a casting issue, not a sealant issue.
gakhar
BC
Update:
Mine said the same citing not wanting to waste a good part, which seems fair. Only couple hundred kilometers since my reseal but its holding for now.
You could always agree to it and request the tech takes a look at the oil pan to see if the casting seems flat/smooth.
ackermann_angle
Gotcha, I authorized them to go ahead with the repair. I will keep you guys posted.
