- Thread starter
- #571
Any of you guys ever drive around with the auto score thingy? The way it seems to score is pretty laughable, but I FINALLY GOT A 100 ON SOMETHING!
for it to score, you need to share your car data, so i do not.Any of you guys ever drive around with the auto score thingy? The way it seems to score is pretty laughable, but I FINALLY GOT A 100 ON SOMETHING!
Same here, I disabled sharing data.for it to score, you need to share your car data, so I do not.
You always have a 100% in my book!Any of you guys ever drive around with the auto score thingy? The way it seems to score is pretty laughable, but I FINALLY GOT A 100 ON SOMETHING!
How do you do that?Same here, I disabled sharing data.
I don't remember the exact menu sequence but I'm pretty sure it can be found in general settings. I can double check later today when I get out of work.How do you do that?
Does that mean logR would not work?
On the other note, LogR still will turn on to show the cars telemetry, but I don't think the lap timer will work, I have not tried it out.
correct. for logR to work on track, you have to enable data sharingHow do you do that?
this is the procedure to turn off data sharingI guess I’ll just turn data off and rely on Garmin Catalyst. I just thought it would be fun for the ranking. But not if I have to share data wholesale.
Not that I've heard so far. I doubt there will be much left of the fronts after 3 days at the track. I'll just swap the factory pads back in.Does it squeak at every stop light?
I annihilated a set of R7's in a weekend, but I still had the backing plates on and was generating a ton of heat. Hopefully they last longer now that I'll be able to keep them cooler.
