PRL Cobra Intake for the 11th Gen Si is Now Here!
Status
Not open for further replies.
PRL Motorsports
Premium Performance Products
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Cobra Intake for the 11th Gen Si is Now Here! 1755817478925-n
After many inquiries, & the popularity of the Cobra on the 10th gen 1.5t platform, we decided to make a Cobra Cold Air Intake System that is compatible with the 11th gen Si! We took our classic Cobra back to the drawing board & made the necessary changes needed to properly fit the intake to the 11th gen Si. This ensures proper fitment & performance that is expected with PRL. We are excited to give you guys another option, & YES our PRL inlet pipes are compatible with this intake.
Overview
Our Cobra Cold Air Intake System for the 2022-2025 Honda Civic Si 1.5T is a complete cold air solution engineered to bring maximum performance and clean, aggressive induction sound to your 1.5L turbocharged platform. This system pulls fresh, dense air from the lower driver-side bumper duct—well outside the engine bay—to promote cooler IATs and more consistent power delivery.
Engineered for both performance testing and everyday drivability, this intake system delivers dependable gains with the same proven quality behind every PRL product.
Performance Gains
Dyno testing confirms that even without a tune, this system brings measurable improvements in power, response, and sound. Tested on a completely stock Civic Si without tuning, our Cobra intake delivered up to:
  • +16 horsepower
  • +9 lb-ft of torque
  • Gains sustained throughout much of the RPM range
  • Peak improvements measured at key points in the powerband
Test results from dyno runs on a stock Civic Si (no tune).
The yellow lines show the Cobra Intake; the green lines show the stock airbox.
11th Gen Honda Civic PRL Cobra Intake for the 11th Gen Si is Now Here! A9drh6jh_1axrbrl_bno-2x-upscale_2048x2048
Key Features
  • True cold air design – Draws air from outside the engine bay
  • Billet 6061 Aluminum MAF Housing – CNC-machined for OE-like fuel trims; anodized black finish
  • HDPE Rotomolded Lower Intake Tube – Lightweight, durable, and thermally efficient
  • Stepped Silicone Couplers – Smooth internal transitions for optimal flow
  • Resonator Delete Integration – Includes plug for factory cold-side resonator box
  • No Tune Required – Standard bore MAF housing maintains factory fueling
Materials
  • 304 Stainless Steel Brackets & Hardware
  • 4-Ply Silicone Upper Hose
  • 6-Ply Silicone Lower Hose
  • Stainless Clamps
  • High-Flow Oiled PRL Cone Filter
What’s Included
  • (1) Rotomolded Lower Intake Tube
  • (1) 4-Ply Upper Silicone Hose
  • (1) 6-Ply Lower Silicone Hose
  • (1) Billet Aluminum MAF Housing
  • (1) High-Flow Oiled PRL Air Filter
  • (1) Upper Mounting Bracket
  • (1) Lower Mounting Bracket
  • All necessary clamps and fasteners
  • (1) Rubber Resonator Delete Plug
  • (1) PRL License Plate Frame
  • (1) PRL Lanyard
  • (2) PRL Stickers
Fitment
  • 2022–2025 Honda Civic Si 1.5T
  • May fit additional 1.5T Civic variants
*This intake does physically fit 2022–2025 Civic models equipped with CVT; however, it is not recommended due to tight clearances near the transmission cooler and front sensor. Customers with CVT vehicles who choose to install this system do so at their own risk.
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
What are the pros and cons vs the existing HVI?
The Cobra will be louder, sees a little more gains, & the location of the filter allows it to pull some cooler air by being completely out of the engine bay. Install will take a bit longer/is more involved with the Cobra, & the location of the filter will take more time to access for service.
btolsen131
Brian
florida
‘25 civic si, ‘11 C6 GS
Where exactly is the filter? Is it at risk of getting water in it? I’m in south Florida so I’m frequently in heavy rain
PRL Motorsports
PRL Motorsports
Export, PA
prlmotorsports.com
11th Gen Honda Civic PRL Cobra Intake for the 11th Gen Si is Now Here! 1756231203634-kg
It sits right behind the fog light housing. As long as you have your fender liner & do not drive through any deep water, the risk of water getting in there is miniscule since it is in an enclosed area.
axion_industries
Chandler, AZ
Been running this for almost 4 years now on our shop 11th gen and so glad to see a perfect fitment version for the 11th gen
Status
