PRL HVI - high temp
beaterfl5
steve
los angeles
fl5
Just installed a PRL HVI and the car seems a little sluggish when laying on the throttle. All the error codes cleared and the install went fine. But I did notice that after some hard pulls around the neighborhood, the temps settled to 140 degrees at a standstill. Am I over thinking this, or is this normal?
11th Gen Honda Civic PRL HVI - high temp imag
matts67
FL
Yes, things get hot when the car is not in motion. You should be looking at IAT relative to ambient temp while the car is moving, because that's when the intake has fresh airflow and is more relevant to actual performance.
tibwolf
When in motion during normal driving, my IATs are around 20 degrees F higher than ambient.
naafl5
Maryland
I had the same question on here I think. Tis normal at a standstill.
beaterfl5
steve
los angeles
fl5
This makes more sense. Thanks for the clarification. Current temps are 20-30 degrees above ambient when moving so I think we’re all good. Thanks
Shankmeyster
AZ
23 Type R
That's strange. I see 10+ or less while moving, but the Si version also has a cold air option that I route through the foglight opening.
