coldradio1
Oliver
Nashville, TN
After tariffs. How much are people paying for Project Aero lips now a days?
Not sure. I got mine before the tariff BS. If you want one that’s super similar (same material, similar design), there’s an American manufacturer that’s worth looking at. Check out RSplitters. They do a textured topside of the lip that looks really nice.
scottjua
Scott
Plano, TX
I paid $25.79 extra to UPS for the import tariff on top of part price plus shipping.
LogicalCC
Chris
Just want to give a shout out to CTR for sending the STRIX kit a while back.
I was finally able to install my project aero lip and it went fairly easily with the help of this upgraded hardware kit.
Highly recommend both the product and the service I received. Top notch.
  • Like
Reactions: CTR
CTR
CTR
strixauto.com
2023 Civic Type R, 2020 GX460
Robo7
Can confirm. Used this kit and it not only made the install easy, but the hardware is much higher quality than the stuff that came from Project Aero.
  • Like
Reactions: CTR
dwag88
David
Chattanooga, TN
Just ordered the lip and this kit. I've never done any sort of bodywork mod on a car before, but I really like this one. It looks factory.
  • Like
Reactions: CTR
blitz423
Orange County SoCal
okay today I got the Strix hardware kit. Very fast shipping. Got lucky and kit came a day earlier than expected via USPS. I see now why people would have a hard time installing with the original hardware from Project Aero. Some areas can get pretty tight to fit your arm in. It's still a little tight for the bolt by the washer fluid tank but doable through the fender well. The Strix kit made life easier for sure. I can see why the Track hardware some people would want for a more stiff attachment but then it's pretty much same hard install as the original PA hardware. From what I can tell not going with the track hardware and using the flat wide washer/nut the splitter felt plenty stiff with a little flex/give for my daily/canyon use.
I now also recommend people get the Strix hardware kit along with their Project Aero splitter.
I also recommend have a friend help you to make things even easier.
CTR
CTR
strixauto.com
JC
Dayton
2016 Accord Sport
Has anyone installed the side skirt extensions and rear spats, and if so, is the hardware on those adequate from Project Aero? Fyi just ordered your install kit!
  • Like
Reactions: CTR
CTR
CTR
strixauto.com
Thanks for your purchase! The side skirt extensions and rear spats are held on with self-tapping screws that require drilling into the body. Not something I was willing to do so I never pursued it personally but from what I understand they are not difficult to install.
blitz423
Orange County SoCal
That might have been true for the earlier version but I installed the sides and rears from project aero some months ago and you don't need to drill into the "body". You DO need to drill holes in the plastic of the sideskirts and a single extra hole for the each of the rear spats. Since you make your own holes you have a little room to play with how far you want the side splitter to stick outwards. They are held on by pretty much the same hardware as the front splitter project aero provided. Bolts/washers/nylon nuts. It is a bit of a pain in the butt because the side splitter is so long that you need to support it in at least 3 spots so the splitter doesn't flex so much while determining hole locations. I tried supporting it near the front and rear up against the sideskirt with 2 jacks but the middle just bowed down ALOT. Then you try supporting it in the middle and there is still a little bit of bowing in between the supports but not much.
Shaka13
Jose
DALLAS
2018 FK8
Anyone used the PA front lip paired with the Mugen lip … wondering if it would fit to add some protection for the Mugen lip
getRIGHT
That wouldn’t work together but racebred components makes a splitter that does what you are thinking with that lip
