Regarding the problem of connecting the logr with the mobile phone, the pin code cannot be displayed
geekatthewheel
Spain
BMW M2C, FL5
couple of checks, do you see TCU connection on the unit? I went to a supermarket parking outdoors to activate it. Have you done a factory reset of the head unit?
Fingers crossed that helps you!
SaVitar
SaVitar
bkk
Haha, hello, what is the tcu connection? I don't understand
geekatthewheel
Spain
BMW M2C, FL5
When your infotainment unit starts you will see on the top right I believe the symbol of a little car with some wave like icon. I remember reading in the car user manual that to use logr with the app that had to be established. Hence why I went out of the garaje to set it up.
I will take a picture next time I drive!
SaVitar
SaVitar
bkk
Okay, no problem. Waiting for your picture.
geekatthewheel
Spain
BMW M2C, FL5
hi man! Here is picture with the TCU connection I meant. I believe the manual specifies that connection must be established for the mobile sync of LogR2.0, but I might be wrong. Hope it helps!
11th Gen Honda Civic Regarding the problem of connecting the logr with the mobile phone, the pin code cannot be displayed IMG_20230713_204251
This status display opens up by clicking on the top right of the screen.
SaVitar
SaVitar
bkk
What does tpu mean, is that when the car system connects to the cellular Wi-Fi, it will show that the tpu has successfully connected?
geekatthewheel
Spain
BMW M2C, FL5
Hi man! I might have made a typo and it is actually TCU. (telematics control unit), it might be related to how the car communicates with the server when enabling the logR. I will capture a snapshot of the user manual and send it, here in Spain the type R gets a dedicated user manual.
Any luck so far?
katch922
Raf
2024 CTR
Same issue, I will try some of the suggestions mentioned and give feedback. Mine doesn’t even show a user id, they are both blank lol.
katch922
Raf
2024 CTR
Thanks for the tips, worked just fine.
All you need to do is go to connections, wifi, disconnect from android or apple care play and connect to personal hotspot on your phone. Once that’s done, gives user id and pin.
No need for any wires.
Djseto
I connected to my WiFi hotspot and while I get the PIN, I also get the no server connection error. Went through a factory reset and still no luck. Any more ideas?
MrB
UK
I've been giving this a go too and my car won't connect to any WiFi network, including my phone's hotspot. Any ideas?
