Softcore Rear Motor Mount Setups (inserts)
HKSpeed
Orange County, CA
FL2 6MT
You're not softcore, unless you live softcore ? ?
I was encouraged to write this thread after chatting with a forum member about rear motor mount (RMM) options that are softer than PRL, but harder than stock FL5. I noticed older guys (including me) find the PRL RMM has too much NVH. I have a 2.0 (FL2) and this was my journey to find the Goldilocks RMM street/daily driver setup.
Version 1: I didn't like how the engine rocked between shifts with the stock FL2 mount, so I bought a Whiteline insert in November 2024. The NVH was tolerable until I turned on AC five months later. I couldn't tolerate the NVH with AC on. I later discovered this insert is rated 95A (on a scale of 60-95A).
Version 2: I installed a FL5 RMM. No NVH. Coming from the Whitline insert, the FL5 RMM was too numb. I wanted more stiffness.
Version 3: I replaced the FL5 insert with a yellow PowerFlex FL5 insert, rated at 70A. NVH was still too much with AC on, but less than the Whiteline. NVH was very minor with AC off. The amount of feedback between shifts was perfect, but I couldn't stand the NVH with AC on. I bought it from this eBay seller with free shipping. PowerFlex charges $8 shipping.
Version 4: I discovered this thread and learned about PowerFlex's FK8 insert (choose 80A or 95A). Instead of buying another insert, I modified the Whiteline insert to PowerFlex's design. I installed it with the stock FL5 insert in the FL2 mount. No NVH with AC on. Minor NVH in reverse below 900 RPM. Here it is on eBay with free shipping. I am not affiliated with PowerFlex nor the eBay seller.
I plan to go back to Version 3 once the weather cools and I stop using AC daily.
I noticed NVH with AC and in reverse is affected more by the smaller gap of the RMM. The larger gap affects engine rock when shifting. That's probably why the stock FL5 RMM has an insert in the large gap only. Maybe I'll modify the PowerFlex insert by removing one or both small gap inserts.
11th Gen Honda Civic Softcore Rear Motor Mount Setups (inserts) 1750868073135-ca
11th Gen Honda Civic Softcore Rear Motor Mount Setups (inserts) 1750868119915-0m
11th Gen Honda Civic Softcore Rear Motor Mount Setups (inserts) 1750868129028-vl
List of RMM options (in no particular order) for reference. I chose to try different inserts because that's cheaper than buying several RMMs. 🤑
Perrin makes a 70A insert for 10th gens, but should fit 11th gens. The insert for the FK8 has a bump in the top gap filler, so I would use their Si insert in an 11th gen.
HKSpeed
HKSpeed
Orange County, CA
FL2 6MT
i hear the passenger side motor mount will wear out quicker with a stiffer rear motor mount. just something to consider.
My first thought after reading that: "what aftermarket motor mount options are available?" ?? That led me to find Hasport's kits for 1.5t and 2.0t. I guess I'll have to replace my 2.0 mouts with OEM when the time comes. ?
NeRO_CTR
Joeeezy
Commiefornia
This is very helpful, thanks for doing the legwork. I'm not a fan of contributing to NVH myself. It’s already hard enough to choose the right tire, let alone deal with mounts. In the future, it'll be nice to know we have some options closer to OE with a bit more durability.
side note: has anyone tried the old school caulking fill?
Back when my wife wanted to build a JDM-inspired 2005 Honda Accord, we used Hasport mounts. For the first few months, the NVH was pretty annoying. But once the mounts settled in, the improvement in drivability was night and day.
NeRO_CTR
Joeeezy
Commiefornia
Yuppp That! Thanks.
Has the 3m's durometer been tested or noted in the mfg. data sheet?
absolude
GTA
i have the Powerflex yellow and it's very soft if you are looking for something mild
Are you using the Type R insert with the Si mount?
I wasn't able to find an insert for the Si.
absolude
GTA
Sorry. Using it with a type r rmm
Thank you for sharing! Both parts are for FL5?
Seems that there are a lot of variables and it can get confusing.
For all I know the 8th. gen. mount that I filled with window weld some 15 years ago may also fit, lol.
