Spoon Springs with ITS ADS Module
Tickle
Wild. We have a family cabin in Gettysburg.
Much snow here. We have a little from the storm but the roads aren't bad. I will probably not have to drive the FL5 in the snow since I work from home.
That is wild! My family celebrates Thanksgiving/Christmas all at once early in December so we don't take them away from their significant others during the actual holidays. We recent a place in Wintergreen, VA.
I'll be driving out there this spring/summer to visit some battlefields and Monticello as well as find some driving roads.
BigBird
Spoon Springs
ITS ADS
18 Inch wheels
It certainly isn't too soft. I run AS tires and the change from one AS to another is more noticable. (DWOS6+ vs Pirelli P Zero AS+ 3?)
Pirelli runs true to size. DWS06+ runs narrow and would need a 275 for similar width as OEM track.
Both tires are similar, but the Pirelli is a bit newer in tech and according to Tire Rack has an edge in the wet.
GIChoe
Thomas
NorCal
2024 Civic Si
I have Spoon springs and the ITS module. I've always run Individual mode with suspension in comfort, but I now have to put that particular setting in sport so that I don't scrape on certain speed bumps and parking lot exits. I might end up returning to stock ADS module and selling my ITS module.
Ac12
Ali
Ontario CA
2008 Accord
Hey there, any update on this or someone else...I'm thinking of going with the type S module on spoons?
GIChoe
Thomas
NorCal
2024 Civic Si
I haven't gotten around to putting the TypeR module back in. I will say that the ITS module on Spoon springs is perfect as a daily.
Nikw91
Nik 772typr
WPB, FL
2025 CW FL5
Anyone else want to chime in on ITS module and spoon springs?
Already have ITS module, thinking about Spoon springs now
Terkoiz
Toronto, Canada
2024 Honda Civic Type R
Just going to echo what was said above in that I don’t find the combo too soft myself. Perfect for a daily driver use case if you find yourself on some bumpy roads more occasionally than not.
jdezee
Jack
sanford, FL
I am going to be getting spoon springs soon. I recently changed to a 275/35R18 tires on +40 wheel set up. I also have the Type S ADS module which I have had for a few months.
The tire is a Advan Apex v601
I was unhappy with the change in the driving characteristics of the car. It felt way to soft and floaty for my preferences. Steering also felt more numb. I have had 20mm spacers on the car for quite some time so nothing was due to moving to the +40 offset.
I recently went back to the Type R ADS and the stiffness is perfect. The drama is there when I want it in +R mode but not nearly as bumpy when on the 265/30r19's. The +R mode is very usable with the 275/35r18 tire.
I just hope the addition of the Spoon springs doesnt take any more edge away from the dampening and steering.
Tickle
I am going to be getting spoon springs soon. I have 275/35r18 tires on +40 wheel set up. I also have the Type S ADS module.
What tire are you running?
TheFactor
Factor
So Cal
2025 CW Civic Type R
Just thought I would chime in.
I’ve been running the type S ADS on stock springs for about 2 months and been very happy with it. Yesterday I had my Spoon springs installed and I’m very very happy with this combo . It’s early on but feel no need to switch back to the stock ADS as of now. I’m loving these Spoon Springs to . Other than just a little spirited driving I love the feeling and feed back. In a few weeks I’ll be heading out to the canyons after I get the alignment and I’ll post back here but I have a feeling this setup will be perfect . At the shop right after the install but she should settle a little more “and has”??
11th Gen Honda Civic Spoon Springs with ITS ADS Module IMG_1639
