Stock height
cubbies4life1993
sam
wisconsin
2022 honda civic si
So I bought a 2022 civic si and it is already lowered I live in Wisconsin and am looking to restore it back to factory height for winter. What would be the best way to do it. Any advice would be greatly appreciated
2025 FL5 Civic Type R
Depends on what's done to it. If it has aftermarket coilovers, you'll need OEM shocks and springs. If its just lowering springs, you'll need OEM springs. If you dont want to spend a bunch of money at the dealer, I'm sure you can find decent sets on FB Marketplace.
ModJPB
Jason
Take the front wheel off and take a picture of your front spring and strut setup. Send it to us and we can give you a more definite answer.
Most likely just need a set of OEM Si springs. You can usually get a used set off eBay or FB marketplace for a little over $100. If you can't find a set, they are surprising not much more cash getting new ones from the Honda dealer.
The rears a very easy to swap out. The fronts are a pain and require a spring compressor that can also handle one of the springs is reverse wound. Not to mention fatal to you if you don't do it correctly.
