TSP Stage 1 Tune for the 2017+ Civic Si (Cobra Race Support Included!)
davemarco
2019 Civic Type R (CBP), 2013 Audi TTRS
KCtrl hit .49 this morning and is holding even with some quick rolling pulls. Running off-brand 93 Octane gas.
davemarco
Is there a new button combo for using launch control? Or is it the same as the previous Two Step functionality, just with on the fly adjustments now?
Micah
Toms River, NJ
'17 Si 4DR FlashPro +9psi (3k-14k) Ktuner TSP Stage 1(14k-30k+) '17 Traverse LT AWD
Can only speak to the Hondata version of the map, while stopped clutch to floor, hit cancel, revs jump up to show where it is set. Can then click + or - to adjust, then cancel to check it's where you want it. To use it, clutch in, max throttle..... and proceed to burn/wear the hell out of your clutch. :)
luispe7
Luis
Hollywood, Fl
2023 Civic Si Sedan
To use: clutch to the floor, shift in 1st gear, floor the gas pedal? And how fast do you release the clutch? Just normally or can just let go without pause
Micah
Toms River, NJ
Yep. Assuming you still have the clutch delay valve in place I would think just dump the clutch.
Micah
Toms River, NJ
How many Hondata users of this map? Wondering if anyone has received an updated map since last night. Now debating if I should purchase ktuner (for the better version of the map) or just flash back to the Hondata +9 map.
D-RobIMW
www.imwtuned.com
Derek
Carlisle, PA
'24 DE5, '98 EK9, '91 NA1, '18 NC1, '23 296GTB
I just got off the dyno for the day and am sending updates out shortly in the order I received responses.
But... I can tell you there are numerous benefits to ditching the current flash hardware in favor of the other.... And if you switch, I'll honor your purchase and shoot you the other version, complimentary.
krees
FL
2018 Civic type r & 2017 Subaru WRX
I got the map loaded and went out for a quick test. Once I got on my straight it started raining...boo. More testing to come obviously but I didn't get any pulls due to the rain. Super stoked to get a feel for it though.
Thanks again @D-RobIMW!
d1zguy
VA
19' Mustang GT Premium
Liking the tune. I have about 14k miles on vit's tune. I feel the top end is better on TSP's but the low end is better on Vit's stage 1. I feel myself having to stab the throttle more to get the same oomf from TSP at low rpm.
d1zguy
VA
That torque shift to the right/later is a good thing for the clutch and the rest of the driveline.
yes, my stock clutch wasn't happy at times on vit stage 1. especially during the winter. But If I had a clutch i probably prefer vit stage 1. But I'm sure TSP can accomodate a more aggressive tune suited for an upgraded clutch. stage 1.5 or stage 2 tune
Sly_Si
Willi
San Franciso, CA
2018 Civic Si sedan
Hold the Cruise "Cancel" button for 3 seconds and let go. The Tach will jump to the number corresponding to the selected slot. Use the +/- buttons to cycle between the tunes, and when ready, press and hold cancel for 3 more seconds, then release. That selects and locks in the slot. The high powered tune is on Slot 3, in Sport Mode.
Thanks, but apparently that option ia exclusive for Ktuner only.. i use Hondata, and i can only switch between Normal mode and Sport mode
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
:imnew:
Plan on purchasing ktuner soonish. I feel like most leans in this direction over Hondata. Deff plan to go with this TSP Stage 1.
Have never done it before. Whats the difference in V1.2 and V2.0? Please be like Denzel Washington and explain it to me like i' m a 5 year old.
Should I just go all in and get 2.o? Total worth?
I plan on installing Catted DP/FP and PRL Intercooler
Already have STREET Cobra Intake and I see a Tubro upgrade in my distant future. Of course a new clutch before this.
I live in Raleigh NC
krees
FL
:imnew:
1.2 has no display; v2 has a touch input display. All other functionality and capability are the same as far as I know.
