BuntaTypeR
How'd you go about disabling the ABS code? I used a resister on my 08 SI when I swapped for DC5R Recaros.
I tried using the resistor trick, but it didn’t work, so the issue is always present. I’m not too concerned about that code since I understand what’s causing it.
lmtlsauto
LMTLS Auto
shop.lmtlsauto.com
getRIGHT
Installed the Infinity Designs turbo inlet today. The CF weave doesn’t go exactly the same direction, but it still is not offensive to me. I think it looks great, not as good as the full Infinity Designs intake though.
Now I have to find CF radiator cooling plates that work with the Gruppe M intake or modify the ARP ones.
That looks fantastic!
I have yet to find cooling plates available for purchase for this intake yet I have seen pictures of them without any info on the maker.
I’ve been holding out trying to not to cut up the APR plates I already bought.
CivR
Chris
Washington
Thank you! The APR plates you have how is the fitment? Do you have to cut the middle and driver side piece or just the middle piece?
getRIGHT
It rate the fit as….. just ok. Of you are OCD then it will fall short
Here’s a pic of just the front mocked up and all 3 sides mocked up.
I placed some painters tape on the front piece to give a guideline to how much to cut.
I think you could get away from cutting the driver side piece but I do also have the WOT hood struts installed so I will have to notch the end pieces regardless to fit those
11th Gen Honda Civic What did you do to your FL5 today? IMG_2228
11th Gen Honda Civic What did you do to your FL5 today? IMG_2229
SKINNIE
DFW TX
ISF, 23' BB FL5
Is it just the GruupeM intake that requires trimming on these CF shrouds? The APR pieces are like $300 each. I sure as hell don't want to hack into them to fit lol
getRIGHT
I hear ya, which is why I haven’t brought myself to do it. I’m holding out to find a brand that’ll fit properly
The APR pieces are made to fit a stock intake box so I have seen other intakes that also need some trimming to various degrees
