19’s, had Advan GT’s in 18 before
This spec to me is perfect
OEM tire size? or did you go to 35 aspect ratio for more sidewall height?
Looks awesome, I am trying to decide between keeping the OEM rims and going 35. or getting 18" rims with 35 aspect ratio tires.
For me, functionality trumps looks... I am concerned about pothole damage to the rims and tires, which is why I am looking at more side wall. though I am not sure that going from 30 to 35 will give any more protection...
RODSCIVIC
Yup OEM tires. I was a bit skeptical because of the 19x10, I thought it would stretch but it’s perfect. A35 would provide more comfort but take me out of the $200 OEM per Tire market 😂. I don’t have the ITS Module but am considering it although the ride quality is OEM. But I’ve heard good things about the ITS module.
Xmetal
CTR, S3
Or you can go 275/30, which will give you a bit more sidewall and contact patch width at the same time - win, win!
I forgot that I can get OEM tires under $200. thanks for the reminder.
though on the other hand, Continental ExtremeContact DWS 06 Plus 275/35ZR19 ($282 at Tire Rack), have a 50k mile warranty which makes them cheaper per mile
side note: Michlines PS AS4 with 45K mile warranty on my previous 07 FA5 Si only lasted only 14k miles, and I got substantial prorated discount for the next set, no questions asked, and that's a good thing since I have no idea why they got bold so quickly :)
I have the ITS DE5 module. for me (and my 61 years old back) it makes a noticeable difference.
FL5 +R was not usable for me on street or freeway driving, while DE5 is tolerable...
I have individual mode set to comfort with the DE5 and I like it a lot for daily driving, freeways and streets. OEM suspension, tires and rims.
my top choice is actually 275/35ZR19 Continental ExtremeContact DWS 06 Plus
but will take at least a year or two before I'll need new tires.
the OEM tires have 4k miles on them. based on past experience with 07 FA5, both original OEM and various others, I do not expect the OEM tires to last more than 10k miles :)
Xmetal
CTR, S3
Saw this posted and wanted to try it out, definitely works a lot better than the OEM charging pad, and doesn't slide around. Snaps into the "rails" of the charging pad.
MagSafe-compatible Phone Charging Adapter
JSAUX MagSafe Wireless Charging Pad
I gave up trying to use the OEM pad or modify anything in that area as that's an awkward area to put a phone anyway. I ended up just using a Proclip mount and an Amazon charger/holder. The holder part works quite well. The charging part - not so much :( At least it's charging, albeit, very slowly instead of just heating up my phone with the OE pad.
11th Gen Honda Civic What did you do to your FL5 today? PhoneCharger
Xmetal
CTR, S3
I would do 275/30 or 275/35 too if the OE tire weren't so inexpensive! Unless something changes in pricing, I'll be sticking with the OE tire.
Since you're in SoCal, I would highly recommend the Continental ExtremeContact Sport 02 instead as it has much better performance than the DWS. We have it on my wife's S3 and loves it!
CivR
Chris
Washington
It rate the fit as….. just ok. Of you are OCD then it will fall short
Here’s a pic of just the front mocked up and all 3 sides mocked up.
I placed some painters tape on the front piece to give a guideline to how much to cut.
I think you could get away from cutting the driver side piece but I do also have the WOT hood struts installed so I will have to notch the end pieces regardless to fit those
The little nub with the blue painters tape on the middle sections doesn’t bother me as much as how the fitment with the right side piece doesn’t line up. Also having to notch them for the hood struts hurts a bunch too. I have those same hood struts. Thank you for this post. I’m going to hold off until there’s a solution or at least one that requires less modding.
I think if you made really precise and intentional clean cuts and got the pieces clear coated it would come out alright.
