Curious to hear your opinion on the change in driving dynamics once you install all 4 spacers, especially given all of the other mods you’ve done to your car so far.
So far I can say with just the front 2, the ride just seems a little tighter and more planted and a little smoother with the wider stance. Can't want to see how it feels with all 4.
atlcivic
E
Atlanta
BMW 1M
Well widening only the front will help reduce understeer on a fwd car, so it can be misleading to base your expectation about all 4 on that alone. Either way, I’ll look out for your findings!
nashville
Rich
1998 honda civic Type R ek9 // 2025 CBP CTR
Had a bit of a late start today, but changed the fronts to the Paragon rotors and Dixcel M pads, and installed the Bonoss 15mm spacers. That fitment with the OEM wheels look so much better now. Will have to do the rears tomorrow.
Nice! Thing is begging to be lowered now
It does look a little higher since it was jacked up and the suspension didn't settle, but definitely will be lowering it eventually.
Installed the rear Paragon rotors, Dixcel M Type Pads, the other 15mm wheel spacers and the Wunderladen Rear Caliper Bushings.
Braking with the new setup is great, definitely has a bit more bite and a firmer pedal.
With all 4 spacers installed the car does feel more planted with the wider wheel base. It also seems like with the added mass of the spacers that it may be absorbing more of the bumps on the road, there seems to be a little less harshness when in Sport or +R mode.
11th Gen Honda Civic What did you do to your FL5 today? 1766367494939-4z
11th Gen Honda Civic What did you do to your FL5 today? 1766367509063-hn
SpoolinFK8
Gogi
NY, NY
2024 Honda Civic Type R FL5
Man that looks dope! U should try a de5 with the damn proximity sensors. I bite my nails. Took a while to undo the clips. Luckily had a friend holding the bumper while I fought the clips
Thanks man, i have a vision for this car just trying to unleash everything few mods at a time. 😂 i can only imagine, when i had the FK8, removing that bumper is a nightmare. The amount of clips, just to remove it.
Buddy of mine gave me these lug nuts from his FK8 he sold, apparently they are lug nuts for Porsches. They are obviously 14x1.5 with a radius ball seat and are chrome. Don't know if they are steel or aluminum, but seems to work well. They are a 19mm hex instead of 22mm like the OEM lug nuts. I kinda dig the look. Waiting on some wheels locks that should hopefully match up.
11th Gen Honda Civic What did you do to your FL5 today? IMG_4262
Parthenius
Colin
Chicago, IL
Well,I think I broke a clip on the console while trying to change the aftermarket shift knob. And whoever changed out the OE knob removed the lock nut, so I didn't even need to pry off the console.
Now to find someone with gorilla grip strength that'll overcome loctite...
