Decided to put in this inlet tube that’s been sitting around for a few months. Not sure when I’ll actually be getting my TSP downpipe so just wanted to enjoy it.
11th Gen Honda Civic What did you do to your FL5 today? IMG_2180
The install is not hard but uninstalling is never fun. The lone harness at the very bottom of the car was a pain to unclip and prying open the harness wire cover took the longest time. Otherwise, everything lines up spot on.
11th Gen Honda Civic What did you do to your FL5 today? IMG_2181
It also makes a bit more sound revving in neutral. Will see how it is when I drive tomorrow.
®ichyP
KP
Fort Lauderdale, FL
24' BBP FL5 Civic Type R
Got this sunglass holder off AliExpress for cheap and thought I'd give it a try. Happy that I can now free up my door pocket and have my sunglasses out of the way
Love it!! I did this mod a few months ago, real convenient and a life saver for my Raybans ?
DR_FL5
Puerto Rico
FL5, AP1, C6Z06
Which setting did you go with? I have the RV6 rear bar not really sure I need the rates the karcept bar can provide
2/2 not much difference in the street driving normally
But driving spiritedly definitely can feel the rear wants to turn in more. Hopefully we’ll get an autocross event soon
Really sorry to read and see this. Glad no one was injured. The car looks busted up pretty good. It's likely this one is a goner, unfortunately. :(
WeudS
Daoud
MA
2023 RR CTR, 2023 MDX Type S
Me and my car have gotten really personal in the last week and a half. Rigid collars feel amazing after the install but I'm not sure what they feel like on the stock suspension setup. I've been running the RSR coilovers with rv6 suspension components for the last month or so.
The turbo and intake combo sound amazing and I wish I had an external mic to mount somewhere to record it. In the mean time the tune is being worked by @Jester04.
Oh I also, destroyed my driver side door like a moron so there's more to do. Luckily resale value is not relevant for me. This thing isn't going anywhere as long as I'm alive.
Installed this week.
HEL Braided Brake Lines
XDI 1400 Injectors
FULL RACE HPFP
Ti Stud Kit via TSP
GruppeM Intake
Spoon Rigid Collars
RV6 Front Pipe
RV6 R660AS Antisurge / T51R RED Ball Bearing Turbo W CF Pipe
Previously Installed
Highwall Black Carpet
Red Leather Shift Knob/ Spoon Aluminum Shift Knob
Type R Trunk Tray
Honda Carbon Fiber Spoiler
Alcantara Steering Wheel
Illuminated Door Sill
Seat Back Protectors
Hondata Flash Pro
Lasfit Reverse LEd
Lasfit Rear Turn LED
Lasfit Trunk Area LED
Acuity Shifter Cable Bushings
PRL Rear Motor Mount
Flapfab Stone Guards
Hypersuede Front Seat Covers
Overland Designs Shift Boot, Center Console Wrap
RV6 Adjustable Rear Lower B Arm
RV6 Adjustable Chromoly Rear Sway with Billet End Links
RV6 Adjustable Rear Lower A Arms
RS-R Front Pillowball Upper Mounts
RSR Best*i Active Coilover
DW300C 340lph Compact Fuel Pump Kit?
Mishimoto Aluminum Expansion Tank
PRL Black Intercooler / Charge Pipes
Paragon 2-piece Rotors Rear Pair 350mm x 11mm (13.78" x 0.43")
Paragon Track Performance Big Brake Kit (PA015/PA035 6 piston)
Waiting to show up
SPOON SW388 19 9.5 +45
SPOON OIL CAP FILTER
KYO-EI RACING COMPOSITE R40 ICONIX M14XP1.5R RADIUS SEAT SET BLACK
TSP Downpipe- Black
Purchase Later
Hondata Can Flex
Acuity Stage 3 Shifter (Release when?)
Ignore the unbolted water lines. This was corrected.
11th Gen Honda Civic What did you do to your FL5 today? PXL_20240907_143311150
11th Gen Honda Civic What did you do to your FL5 today? PXL_20240907_143301018 (1)
XDI 1400 Injectors
FULL RACE HPFP
Ti Stud Kit via TSP
GruppeM Intake
Spoon Rigid Collars
RV6 Front Pipe
Type R Trunk Tray
Hondata Flash Pro
Lasfit Reverse LEd
Waiting to show up
TSP Downpipe- Black
Purchase Later
Hondata Can Flex
All the little issues I would say a little more than personal. You guys are in an intimate relationship by now with how she has been screwing you over.
...overnight parts from Japan.
I wanted to partially close the loop on this. I was able to get this installed a couple weeks back. The system consists of the front pipe (purchased seperately) + mid-section + muffler. Here are the photos:
Before
11th Gen Honda Civic What did you do to your FL5 today? 1000028362
11th Gen Honda Civic What did you do to your FL5 today? 1000028347
11th Gen Honda Civic What did you do to your FL5 today? 1000028349
After
11th Gen Honda Civic What did you do to your FL5 today? 1000028351
11th Gen Honda Civic What did you do to your FL5 today? 1000028358
11th Gen Honda Civic What did you do to your FL5 today? 1000028350
11th Gen Honda Civic What did you do to your FL5 today? 1000028356
11th Gen Honda Civic What did you do to your FL5 today? 1000028355
11th Gen Honda Civic What did you do to your FL5 today? 1000028364
11th Gen Honda Civic What did you do to your FL5 today? 1000028352
11th Gen Honda Civic What did you do to your FL5 today? 1000028363
A few notes:
  • Fitment - 10/10. Every portion of the system from the hangers to tip alignment to clearances are spot on.
  • Packaging - Very good as is the quality of the included hardware. It's clear great care was taken to ensure the parts aren't damaged during shipping. Everything you need to install the exhaust is included in the box including some metallic decals if that's your thing.
  • Weight - The savings over stock is 14.52 lbs, or 30%. The breakdown is as follows:
Stock Exhaust - 40.26 lbs (18.3 kg)​
Stock Front pipe - 9.9 lbs (4.5 kg)​
Total - 50.16 lbs (22.8 kg)​
Fujitsubo Exhaust - 28.38 lbs (12.9 kg)​
Fujitsubo Front pipe - 7.26 lbs. (3.3 kg)​
Total - 35.64 lbs. (16.2 kg)​
It always amazes me how lightweight titanium is relative to stainless steel when in your hands. The pieces are just that light.​
  • Sound - The sound is what most are probably here for. So, how does it sound? Phenomenal! It's not a loud system and I would characterize it as a mild to moderate tone and volume increase over the OEM system, which is exactly what I was after. Since the exhaust is constructed of titanium with two resonators, the acoustic profile is different than a stainless variant. It's not raspy, boomy, or deep. The sound is "cleaner" and has more of a "tinny" or metallic sound when you get into it. Vibrations (sound) on titanium ring off differently so that tracks. Drone is very limited to non-existant. I can't say the system doesn't drone; however, you'd have to try incredibly hard to find it. A few folks I've spoken to who have this exhaust on the FL5 claim there is no drone. I wouldn't take umbrage with that assessment. In the opening, I mentioned the loop on my initial post is only partially closed because: no videos. It's hard to truly capture sound via video, but I'll get some stock vs. FGK videos up in the coming weeks. Standby.
Websitesdown
Just updated my flashpro mini. Downloaded my tune file to my laptop. ECU should be here today, out for delivery now! Super pumped, can't wait to freaking disable the rev hang! I had my 19 SI sitting at 333WHP 340TQ. Have a video attached of me doing a pull merging onto the highway after fixing a sparkplug going bad on me right before a dyno of it. Attached a video of it at the dyno as well below and the dyno sheet pic as well after. My goal is obviously to get this beast meaner then my SI was. I'm going to be doing a video of me doing a merge onto the same highway entrance at some point and will drop that video here as well for everyone's viewing pleasure.
11th Gen Honda Civic What did you do to your FL5 today? dyno si 2024
