jdezee
Jack
sanford, FL
This has been the most significant deterrent in purchasing one, I've yet to see one installed with the boot.....will/can the boot be used with that shifter?
I can definitely utilize the boot if I wanted to. Most opt for the one piece podium shift rod and that does not have any threads, so there is not a great way to attach the boot collar. This is the standard rod with threads. I could use the lock bolt on the shift knob that is the locking source for the boot collar.
I may actually go back to the boot at some point but honestly now that I have it open, I love seeing the beautiful shifter. Something about the mechanical nature and view of it makes the whole experience of driving even more engaging.
princers
Z
25 Type R
some chasing j’s bolts (have to do the strut tower nuts when my strut bar comes in)
11th Gen Honda Civic What did you do to your FL5 today? IMG_9816
Mobias
2024 Civic Type R, 2006 S2000
I installed mine with the stock boot and shift knob. I don't like the no boot look and it's too easy for things to fall in the hole. I don't plan on ever adjusting the shifter from the settings I have now, so it wasn't an issue for me.
NeRO_CTR
Joeeezy
Commiefornia
Appreciate you! I wish to keep my boot as well, especially after buying the alcantara boot.
Summary of everything I've done since I took delivery a month ago:
mounted the license plate bracket using stainless zip ties plus black aluminum license plate frame
https://www.civicxi.com/forum/threads/front-plate-mount-options-fl5-type-r.51181/post-944003
removed the fake engine noise thingy (Active Sound Control?)
swapped in the ITS ADS module/controller
thermoformed black ABS sheet to protect driver side car mat (my Si had heel hole in the car mat and into the carpet below, so I figured that I should attempt to protect the CTR's mat)
Acuity throttle pedal relocation bracket (position C was the best, A was worst)
PRL rear engine mount
WOT Performance HPT cooling plate (ordered)
Hybrid Racing short throw shifter
Hybrid Racing shifter cable bushing
Hybrid Racing shift boot collar
Razo weighted shifter (from my 07 FA5 Si)
Mishimoto Round Steel Core Wood Shift Knob
hardwired Miofive 4K dash cams (front and back)
McGard wheel locks
RokBlokz rally mud flaps + mesh rock guards
FIAMM Freeway Blaster horns (high and low) + two Hella horns via relay
27Won air intake snorkel
41.22 drop-in kill switch
VTT OBD port lock
Votex quick oil drain plug
TPMS w/external valve stem sensors
LED bulb for trunk/hutch
Trunk organizer
Trash can (mounted behind center console)
1" foam on top of the center console (ugly, but comfortable...)
nicer center console armrest pad/cushion
https://www.amazon.com/Car-Armrest-Cushion-Universal-Accessories/dp/B0DC9XQKH
svvitch
New radiator and coolant expansion tank. Had to pull my PRL intake to get the radiator to fit but that's ok I'll get a drop in filter instead ?
11th Gen Honda Civic What did you do to your FL5 today? e3421b26-2835-4ea8-8d1b-1e53d5b6d5ac
svvitch
Bummer, which radiator?
I knew it when I bought it. I could have trimmed the fan shroud but honestly OEM intake is fine. I am not a big fan of the oiled filters. It's the WOT radiator from siwelnosaj on the forum. Radiator fit is tight it's taking up all available space ?
svvitch
I was thinking about a black roof as well. Looks good!
Amm5890
Andrew
2024 CW CIVIC TYPE R - #17038
Went a little overboard with the bride stuff. The seatbelt protectors are genuine from Japan. The arm rest pad and neck support pillows are knock offs but they make traffic a lot more comfy.
11th Gen Honda Civic What did you do to your FL5 today? IMG_1795
11th Gen Honda Civic What did you do to your FL5 today? IMG_1794
where did you get the BRIDE stuff?
the arm rest definitely looks better than my layers of cut up foam pad...
Amm5890
Andrew
