SP R KiD
Matthew
2023 BB CTR, 2021 Toyota Highlander, 2001 F150
I like it and if I didn’t have the OEM + CF wing I’d of definitely done it to the gloss black wing ??It’s a nice touch and Not to much color matching going on.
That’s exactly how I feel. I like the paint matched wings a little, but I tend to find it a little over bearing. This is a pretty happy medium for me.
TheFactor
Factor
So Cal
2025 CW Civic Type R
Again great choice and much more cost effective while still looking really good.
Made a faraday cage to store all of our vehicle key fobs. Simple yet very effective:
  1. Fido glass 0.5L hermetic jar (gasket removed);
  2. Two layers of heavy duty aluminum foil applied to the inside and outside; and
  3. Reflect-A Gold tape applied to the inside and outside to keep the aluminum foil layers in place and more obviously to keep temps in check.
Simple idea that seemed effective at first however, the gold foil tape being added started to reflect the RF signal from the key fobs even after adding a rubber insulating barrier on the inside. Layers of just heavy-duty aluminum foil seem to do the best job so far for blocking the RF frequency range used by the fobs.
Interesting. I guess that’s a testament to the reflective qualities of gold!
Seems to be more along the lines of RF bleeding out from the hinged enclosure having been opened and closed several times compressing the layers and then forming a gap.
TheFactor
Factor
So Cal
My gold tolerance level has just been over loaded for the last time and I think it’s a blessing in disguise.
Now it’s deleted forever ? Welcome to the platinum side.
惹Raizzelle
Raizzelle
BC, Canada
2024 Honda Civic FL5 Type R
Did I make the right decision?
I was really dead set on getting the Apexi Exhaust, but after thinking about having a newborn + a toddler and how cabin noise would affect them, I decided to go with the Spoon N1X Exhaust.
11th Gen Honda Civic What did you do to your FL5 today? IMG_4549
11th Gen Honda Civic What did you do to your FL5 today? IMG_4544
@惹Raizzelle It's been a while, I hope you're well. I hear the Spoon exhaust drones badly. Is that not your experience? Car looks good btw!
惹Raizzelle
Raizzelle
BC, Canada
Heyyy @Clark_Kent , I've been busy with school and life, but everything's good, haha. Thanks for checking in! Hope you and your family are doing great too. ??
Honestly, I don't really notice much of a drone with this exhaust. I'm really pleased with it overall, just curious if anyone could share their experiences with both tho. Haha thank you!
TheFactor
Factor
So Cal
Absolutely and love it ! What springs are you running looks perfect to ????
rondre3000
San Diego, CA
Was just about to comment the same thing. May remove my H&R and go back to my original plan to go with Pro Kits.
Any other side shots @Raizzelle ?
TheFactor
Factor
So Cal
Thanks for the kind words! It’s Eibach PROKIT. ?
Looks wicked ! ???? Also just to note although I don’t own a Apexi I know someone that does and he did mention the valve did make noise/rattle periodically but other then that he liked it. Could be an install issue as far as what position you have the valve at when installed. I’m sure other Apexi owners will chime in :)
惹Raizzelle
Raizzelle
BC, Canada
Here you go, hope this helps!
11th Gen Honda Civic What did you do to your FL5 today? IMG_4282
11th Gen Honda Civic What did you do to your FL5 today? IMG_4285
11th Gen Honda Civic What did you do to your FL5 today? FullSizeRender_VSCO
Thank you very much again! Appreciate the infos you’ve shared. ????
