Xmetal
CTR, S3
Anyone rocking a rigid clutch pedal stop?
I just installed one I had in storage from some guy selling it from his part out. It feels great so far. A lot more satisfying clunk at the bottom of the clutch travel.
Anyone know if this is bad from the trans?
https://www.blackhawkjapan.com/products/rigid-aa1020-2
I wouldn't worry too much about it since the engagement point of our clutch is close to the middle or upper end of the travel. As long as you're not very close to the engagement point, you should be fine.
Mrjustin81
11th Gen Honda Civic What did you do to your FL5 today? IMG_6867
who says you go off roading in the R? ?
TheFactor
Factor
So Cal
2025 CW Civic Type R
@NeRO_CTR Here you go buddy ??
This was just after about one day and I was really surprised how close the numbers were.
FL 25 1/2
FR 25 9/16
RL 25 9/16
RR 25 1/2
? Measured the best I could after a long night lol
Toppyjai
The United States Of America
2025 CTR
Because........... RACECAR spelled backwards is still spelled RACECAR!!! Installed a Defi-Link Advance control unit and turbo gauge. Ripped off the dash to wire the system for a clean install. I connected the Defi boost sensor onto the firewall inside the engine bay, on the passenger side. Wired the red power wire, the black ground wire, the orange ignition wire and the white illumination to the infotainment wires (that's the reason why the dash was removed). The wire that goes to the turbo gauge is on the Defi boost sensor, it was ran through the firewall and up behind the dash to the Defi control unit. The vacuum hose from the Defi boost sensor comes with a supplied T fitting. The T fitting is split from the manifold, one way goes to the boost sensor, the other way goes to the HKS BOV. Seeker cluster meter pods and hopefully more gauges in the future. Much of the install and inspiration goes to Kodawari.FK8's YouTube channel - ... because his gauge setup is so badass!!!
11th Gen Honda Civic What did you do to your FL5 today? scrnli_S9VmUDKzs3gGlm
11th Gen Honda Civic What did you do to your FL5 today? scrnli_iSny3HL173iyec
11th Gen Honda Civic What did you do to your FL5 today? scrnli_ng7F8viYx3K8c0
11th Gen Honda Civic What did you do to your FL5 today? scrnli_HzxKZ87G13jN6L
11th Gen Honda Civic What did you do to your FL5 today? open
11th Gen Honda Civic What did you do to your FL5 today? meter 1
11th Gen Honda Civic What did you do to your FL5 today? 1000169883
11th Gen Honda Civic What did you do to your FL5 today? 1000169885
11th Gen Honda Civic What did you do to your FL5 today? 1000169884
11th Gen Honda Civic What did you do to your FL5 today? 1000169886
11th Gen Honda Civic What did you do to your FL5 today? control
Reference pic of the what the Seeker pods look like........ RACECAR!!!! :)
11th Gen Honda Civic What did you do to your FL5 today? scrnli_29PPyM9HN4ThYU
These pics are from Kodawari.FK8's YouTube video, he wrapped his interior in Alcantara fabric - :
11th Gen Honda Civic What did you do to your FL5 today? scrnli_itGd311fYi34wj
11th Gen Honda Civic What did you do to your FL5 today? scrnli_Q9LztamOAI0826
11th Gen Honda Civic What did you do to your FL5 today? scrnli_1gqah6bs3hfw9L
11th Gen Honda Civic What did you do to your FL5 today? scrnli_E97mr1MwNhI2F3
TheFactor
Factor
So Cal
One Horsepower per Square inch claimed ? I just can’t do it to much bling ? Thought I’d make a little insert on the Air box ?
11th Gen Honda Civic What did you do to your FL5 today? IMG_1651
I’m afraid in time I’ll end up like him ?
11th Gen Honda Civic What did you do to your FL5 today? IMG_1654
NeRO_CTR
Joeeezy
Commiefornia
^^ Looking good Shawn!
FL 25 1/2
FR 25 9/16
RL 25 9/16
RR 25 1/2
I'll double check mine....I'm at 25 13/16 - 7/8. Started at 26.5
TheFactor
Factor
So Cal
Cool , do you have the revised with the blue collar’s?
Settling in nicely
11th Gen Honda Civic What did you do to your FL5 today? IMG_1661
SP R KiD
Matthew
2023 BB CTR, 2021 Toyota Highlander, 2001 F150
Flat-Bottom Steering Wheel | 22+ Civic, 23+ Integra – Unity Performance
Just ordered the above steering wheel. Had a local tire shop mount and balance some tires and they damaged my steering wheel in the process (nice big scratch on the left side.) They honored the damaged and paid for the repairs. Got a shop to quote the fix for ~$1100 so I figured I could pick this up and pocket the change.
Any tips on wheel install? Looks pretty straightforward. My only concern is I've heard of people needing an alignment after install, but I don't think you should need an alignment if you align the wheel correctly, right? It doesn't make sense to me but I've seen enough people talk about it I figured I'd ask.
Bazgab
Rob
Raleigh, NC
Wheel install is super easy. The only tricky part is what you mentioned, make sure you get it on the right spline when reinstalling. No need for an alignment, plus not sure how that would help since there is no change to the suspension geometry.
Wish they had made it foolproof like in BMWs though. They have a keyed steering wheel spline so the wheel can only go on the correct spline.
NeRO_CTR
Joeeezy
Commiefornia
Settling in nicely
yes, they are the updated version with black insulators.
