Ouhei
Alex
Raleigh, NC
2025 CW CTR
Looks great :thumbsup: Been too chicken to color match my wing on my BBP. BTW, how is the antenna cover comes off? Is it clipped on somehow or 3M tapes? Curious for future project if and when I decides to color match it. Thanks.
Thanks! It’s 3M tape. The cover is just one I found on Amazon for like $15. I figured it was low risk, the fitment is pretty good but I may buy an actual antenna to do this with at some point.
Installed the Wunderladen Street RMM and the front LTLD Performance Stabilizer from TSP. Was only able to install the front stabilizer for now, didn't really feel like taking apart the rear bumper.
Haven't really driven it much, but NVH at cold startup is rough just like any upgraded RMM and does die down when the car warms up to idle. Barely any additional NVH with the AC on. Hopefully it will break in like other RMMs and soften a little, but I still have Rigid Collars to install to hopefully help with all that.
I will say, installing an RMM on the FL5 a bit of a pain in the ass compared to the 1.5T.
11th Gen Honda Civic What did you do to your FL5 today? 1760745635541-d3
11th Gen Honda Civic What did you do to your FL5 today? 1760745648778-n3
Xmetal
CTR, S3
ohhh...So you just color matched the cover from Amazon and installed it over the OE, leaving the OE in place? I thought you took off the OE cover and color matched that?
Robo7
I’m tempted to try this RMM. Has anyone tried both the PRL and Wunderladen mounts? I have the PRL and I don’t want to add more NVH but I keep hearing good things about the Wunderladen.
Ouhei
Alex
Raleigh, NC
2025 CW CTR
Correct, I didn’t want to deal with all the wires if I didn’t have to, I figured I’d try this and if it didn’t work out I’d go the more annoying route. Thankfully it looks pretty good so I might be able to avoid the hassle.
CivR
Chris
Washington
Installed the acuity shifter assembly and the Overlands Designs alcantara wrapped center console trim.
Shifter feels good, stock one also felt good. It’s definitely not the same huge improvement that I felt going to a shifter assembly in my 2011 SI. It’s still great. With the center console I did the same layout as another member I saw. There really isn’t a ton of room for variation.
11th Gen Honda Civic What did you do to your FL5 today? IMG_9077
11th Gen Honda Civic What did you do to your FL5 today? IMG_9078
11th Gen Honda Civic What did you do to your FL5 today? IMG_9081
PNEUMA
Jerry
PNW
2025 FL5
Acuity in my car was night and day improvement. I don’t even know how it could be improved upon.
jdezee
Jack
sanford, FL
Finally installed my Spoon springs today. What an absolute nightmare the front driver side was, I had plans to do other work but ended up spending the whole day getting just the springs in. Might have a casualty on the driver side axle seal in the trans, we will see if it starts to leak. 0 stars would not recommend.
The stance looks great though and the ride is great also. The drop was much needed with the SW388's.
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_135310507.MP
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_135320886.MP
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_172827998
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_144138106
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_144134816
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_215604259~2
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_214531837~2
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_215635207~2
11th Gen Honda Civic What did you do to your FL5 today? PXL_20251018_215618271~2
us17094
Tenny
Accord 2.0T 6 speed
How was the install? Looks great!
I installed a set of these a couple of months ago. I had never used/installed a rivnut before so it probably took me a lot longer to set up than it should have. Its a great upgrade and well worth the modest cost.
