floggindave
What did I do with my FL5 today? I put the deposit down to pick it up when it arrives!
Thanks! It’s 3M tape. The cover is just one I found on Amazon for like $15. I figured it was low risk, the fitment is pretty good but I may buy an actual antenna to do this with at some point.Looks greatBeen too chicken to color match my wing on my BBP. BTW, how is the antenna cover comes off? Is it clipped on somehow or 3M tapes? Curious for future project if and when I decides to color match it. Thanks.
ohhh...So you just color matched the cover from Amazon and installed it over the OE, leaving the OE in place? I thought you took off the OE cover and color matched that?Thanks! It’s 3M tape. The cover is just one I found on Amazon for like $15. I figured it was low risk, the fitment is pretty good but I may buy an actual antenna to do this with at some point.
I’m tempted to try this RMM. Has anyone tried both the PRL and Wunderladen mounts? I have the PRL and I don’t want to add more NVH but I keep hearing good things about the Wunderladen.Installed the Wunderladen Street RMM and the front LTLD Performance Stabilizer from TSP. Was only able to install the front stabilizer for now, didn't really feel like taking apart the rear bumper.
Haven't really driven it much, but NVH at cold startup is rough just like any upgraded RMM and does die down when the car warms up to idle. Barely any additional NVH with the AC on. Hopefully it will break in like other RMMs and soften a little, but I still have Rigid Collars to install to hopefully help with all that.
I will say, installing an RMM on the FL5 a bit of a pain in the ass compared to the 1.5T.
Correct, I didn’t want to deal with all the wires if I didn’t have to, I figured I’d try this and if it didn’t work out I’d go the more annoying route. Thankfully it looks pretty good so I might be able to avoid the hassle.ohhh...So you just color matched the cover from Amazon and installed it over the OE, leaving the OE in place? I thought you took off the OE cover and color matched that?
Awesome setup! What front lip is that, looks sick!New wing! Voltex Type 2 1600mm.
Car is dirty, please don't look too hard
That’s the M&M Honda front lipAwesome setup! What front lip is that, looks sick!
How was the install? Looks great!Installed the WOT hood struts.
I installed a set of these a couple of months ago. I had never used/installed a rivnut before so it probably took me a lot longer to set up than it should have. Its a great upgrade and well worth the modest cost.How was the install? Looks great!
