Widening the Track with H&R spacers (questions)
blu_fl5_ctr
rob
cincinnati ohio
2024 BOOST BLUE TYPE R
Prior to purchase I thought I was confident I didn't have to do any modifications.
On the box it says "must shorten existing lugs"?
Does anyone have any experience with this?
My set up is 20mm on rear and 15mm on front. The 20mm box makes the shortening claim. The other box the label is in German.
11th Gen Honda Civic Widening the Track with H&R spacers (questions) 1000002034
GIChoe
Thomas
NorCal
2024 Civic Si
Yeah, the spacers have their own lug bolts, but depending on how thick the spacer is, the existing lug bolts on your car might be too long and not let your wheel sit flush. Time stamped youtube link here to show you what I mean:
TiNuts
Kansas
2024 Type R, 2014 Si
You should be fine with the 20mm. The 15mm may or may not need some trimming.
RODSCIVIC
You should be fine according to this:
Ac12
Ali
Ontario CA
2008 Accord
Have you noticed any difference in ride quality, I'm also looking at 15 front, 20 rears...
GIChoe
Thomas
NorCal
2024 Civic Si
I don't have any installed, I just came across this video while doing research
msos
2025 Civic Type R (replacing BMW M2 Competition), BMW X3M and McLaren Artura
I have 20mm all around and i used OEM lug nuts without a need to cut!
msos
No handling difference of note. As i only do street driving its hard to tell as car was only 6 weeks old when i did the mod.
Ac12
Ali
Ontario CA
2008 Accord
thanks for the reply, and I get it someone asked me the difference with spoon springs and I said the same... Love the drop and ride but can't compare with stock as I didn't get much seat time
SempK
Sam
Socal
25 type R
Does anyone know what's the widest spacer I could install in order to use the stock studs? Meaning....in case if I dont want to install the spacer system with extra studs on it.
CR-X
Chris
Toronto
2018 Civic
In the past, on other Hondas, people have used 5mm.
