Ash @ S2i Audio
- First Name
- Ash
- Joined
- Sep 1, 2025
- Threads
- 6
- Messages
- 116
- Reaction score
- 172
- Location
- Northern Virginia
- Website
- www.s2iaudio.com
- Vehicle(s)
- 2025 ITS
- Thread starter
- #61
Wiring Diagrams as requested!
I included the "before" along with the "after"
Keen eyes may have noticed that I decided last night to make this a totally plug-and-play affair, integrating the factory power source originally for the factory amplifier, to now power the Integrator Device. Since this travels on the same OE harness that also feeds the amplified signal to the speakers, this frees things up to build a custom T-harness between the Integrator Device, Aftermarket DSP/Amp, and the factory speaker wiring, making everything plug-and-play (you just need to provide power and ground for the DSP amplifier, as well as supply your own RCA digital cable of appropriate length for your chosen DSP install location).
This also means that the factory amplifier can be fully removed from the car, and the Integrator Device can be installed in its location in the passenger kick panel.
