How much of the front rotor screw do I need to drill out?
J_D
J
Montreal
This rotor just will not budge! Do I need to drill more than just the head of the screw?
11th Gen Honda Civic How much of the front rotor screw do I need to drill out? IMG_7855
pwp25si
2025 si
Probably rusted onto the hub. Use the two threaded holes and bolts to free it.
  • Like
Reactions: J_D
MrBBQ
Danny
No, don't drill anymore, just the head of the screw needs to be drilled out. Did you happen to use a impact screwdriver to prevent the screw head from stripping? The rotor is rusted onto the hub. Try spraying some WD40 or PB blaster in the screw holes and center ring to try and break up the rust. The 2 screw holes are there to put two screws in and push the rotors off the hub.
J_D
J
Montreal
I realized I was being dumb, for some reason had a brain malfunction and forgot the rotor doesn’t have threads
Hammering the rotor endlessly did nothing but dent it. I had a spare bolt nearby and threaded it into the rotor hub with my impact, it popped the rotor right off. Literally 2 seconds. Gah
J_D
J
Montreal
Yes I tried a impact screwdriver too! Honda rotor screws are not rust belt friendly
marcusm86
Marcus
Missouri
2025 Civic Type-R
you should be able to thread bolts into here and it may help push the hat off the hub
11th Gen Honda Civic How much of the front rotor screw do I need to drill out? 1776557952476-6l
  • Like
Reactions: J_D
tc0566
Jim
Canton, Ohio
2025 Honda Civic Type R
Now clean the hub and coat it with anti-seize before putting it back together. I plan to pull mine and put anti-seize on them this week. My Type R is new.
  • Like
Reactions: J_D
J_D
J
Montreal
Yup, it got the wire brush treatment + anti size on the inner ring.
J_D
J
Montreal
Incase anyone was wondering, the rear rotors were just as cursed o_O
J_D
J
Montreal
Rear rotor hub somewhat cleaned, stud drilled flush, plus some anti seize on the inner ring
11th Gen Honda Civic How much of the front rotor screw do I need to drill out? IMG_7859
MrBBQ
Danny
What rotors did you go with?
J_D
J
Montreal
Front axel is EBC RK2028 and EBC RPX pads
Rear axel is bremson BH01036/Ray 982357 and FK8 2020+ OE pads.
As an FYI, Autozone sells packages of brake rotor retention screws. I had to drill a couple out after 10 years in New England, and yes I first used an impact driver to no avail. Won't ever be a problem for me again in AZ.
  • Like
Reactions: J_D
MoodySara
New England
Just looking at your brakes makes we wonder where they've been,
Why are they so rusty? Are your roads heavily salted?
I live in NH, USA, which uses a lot of salt. Even so, mine don't look like that.
