Sporky McGeuschky
Sporky
Central Texas
Wow, this is pretty impressive. Not gonna ask where you get the Lucci for all these unicorn parts.
Is there any chance you took your FL5 for a Dyno run before getting this cam work installed?
It would be interesting to see before and after with HP and torque, although we already have aggregate "close enough" stats for the stock FL5 platform ...
OR...
Are these cam parts just supposed to be smoother polished and / or higher quality steel, or other quality of life / "peace of mind" upgrade?
Better fuel economy, perhaps? (Yeah, right!)
Agen2integra
Evan
Philly
2025 CW CTR
Such an impressive build, I actually went through all of these pages last night admiring all the work and parts that have gone into this. Kudos to you @nojeebs!!
Also my cat’s name is Geebs, pronounced Jeebs. 😂
nojeebs
nojeebs
25 FL5
OR...
I sell feet pics on my OF.
Actually that's a good idea as I usually just throw on mods, tune it and see what it makes and be content. My buddy is giving me access to use his work's dynapac at a discount so I'll see how much to just baseline it.
The valve train upgrades are to help with mid to high range power and slightly increase the redline. I'm hoping for 7800k ~ 8K. It's also for protection and longevity as the springs can handle more abuse if an over rev ever happens. I'm no engineer on cams but I think they mill them to be more aggressive to allow more air and fuel in to make more power. I went with 4 Piston's 2.5 cam as it's still considered streetable anything more race spec would sacrifice drivability for daily use.
Thank you! NoJeebS handle came from when I made a Nasioc account back in 2004 and my nickname at the time was JeebS (JS are my initials 🤓). JeebS was taken when I wanted to register so I was like....there's no jeebs....oh god typing this out now makes me realize how stupid I was over 20 years ago. I'm looking more and more like a 1st gen product of the internet.
Sporky McGeuschky
Sporky
Central Texas
Hmm... 🤔 Maybe I should make an account myself. I certainly could use the extra disposable income.
Not that I should, but I certainly could. "MidLifeFeet", perhaps?
So that's cool that the cam upgrades will give you that rev overhead "peace of mind" while still being street practical.
Man, once this thread is loaded with proven successful aesthetic and performance FL5 mods, Admin may have to upgrade this thread from a build thread to a reference thread.
Then it will be no longer be called "NoJeebS".
This thread will simply be known as:
AskJeebS. 🧐
I wonder if there's a market for weird shit like toenail fungus. I'd make a killing if that's the case.
I'm not an expert either but I know a bit. The thing about cams is they control the lift and duration of the valves. The eccentric "lobe" on a higher lift/duration camshaft will be taller and wider than OEM. This pushes the valve open more and leave it open longer- MUCH more air enters/leaves the combustion chamber. As a byproduct, the profile changes the way the engine makes power and thus will make it at a higher rpm. Thus valve springs are required to support the extra revs without damaging the valvetrain. You don't HAVE to do the valve springs... but then you would actually be making LESS power within the same rev range. The cams effectively move the powerband higher, but it will make less power at low revs.
I learned this the hard way by buying a Nismo race cam for my KA24E 240sx. I didn't buy springs so thus left the rev limiter where it was ~6800rpm or whatever. It was MUCH slower lol. But it sounded like a muscle car. Which meant absolutely nothing. That cam was designed for full forged internals at 13:1 compression and ITBs. Even with all that it would have made less than 200 whp by my estimation... but would have been cool?
For turbo vtec the rules may change a bit but that's the gist.
As usual, VERY curious what results you get. I swear you're blazing this trail with these parts that do not appear to be very publicly documented. I love it.
nojeebs
nojeebs
25 FL5
Got the car back and boy do the mods work together well. Highly recommend doing the powerflex anti lift kit (I did the street version) has a 2 piece bushing (80A outter and 95A inner) Adds a bit more nvh but nothing crazy. This kit also corrects caster.
Spoon zero bump steer kit clears 18s np. I'll measure clearance when I get home later today and update the post.
UPDATE w/ photo:
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260603_234601629
It's about 3/4 an inch of space left on 1pc 18s. I think 3pc 18s will be fine as well.
First thing I noticed was that it felt very responsive on turn in and with even less body roll. Getting on the gas at lower gears feels more solid as well with less lift. So the powerflex kit is definitely working as intended haha.
Don't skip these mods if you are on, or intend to go with coilovers. Yeah bold, it's that good/important. 🪦
Engine bay pic for attention 😆
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build DSC01400 (1)
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build DSC01321
nojeebs
nojeebs
25 FL5
Ranch Corn Nuts are goated.
Well I went with MDR's g25 660! Not chasing peak power just want to feel the rush while cruising and SoCal winter track days. Their kit comes with all OEM replacement hardware and printed instructions. Only thing left to consider is fuel. I think.
I'm going to guess it'll be another month until I can get everything on which is good since it'll give me time to get used to the power from the otf stage 1 from Cobb. Pushing in the canyons last weekend really got me itching to do some track days but I want to go in hitting the ground hard as I already know what to expect in a 440 at the hub FK8 on e40. I don't think I want to run pure e85 and probably still opt for a blend but we'll see cause as they say: buy once....
cry for months. 😿
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780602065000_R0000912
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780599798000_R0000901
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780599672000_R0000898
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780599830000_R0000902
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780602345000_R0000922
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780602151000_R0000915
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780599962000_R0000907
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780599991000_R0000909
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780602420000_R0000925
nojeebs
nojeebs
25 FL5
4 Piston 625+ Extreme Duty Head Studs came in. I'm skipping on doing the Ferrea valves, as that'll mean more downtime since the head would have to go out for machining. If shit goes boom later on or I lose more brain cells, brain cells lose more likely, I'll go ahead with rebuilding the motor to be bulletproof.
Rather test the waters with minimal effort in mods since plenty of people have pushed this engine to absurd number, at least ot me, compared to what people expected back in 2020 on the FK8.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780784453000_R0000965
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780784345000_R0000964
Extra LDC shift knob came in. I picked up a bare one as I'm thinking of doing something with it if my other project works out. 🤫
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780784128000_R0000963
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1780783997000_R0000959
Sporky McGeuschky
Sporky
Central Texas
Moar Unicorn parts!
Half of these parts don't even look like they are made on Earth.
Where do you get this stuff...
Mars?
nojeebs
nojeebs
25 FL5
Moar Unicorn parts!
Mars?
Bwahaha. The bags under my eyes are like UFOs searching for parts all through the night.
Update on the Cusco front lower brace....still didn't put it on. 😅 But I did redo the Cleib front lip. The rivnuts Cleib supplies aren't made for plastic. I can understand their thinking in putting rivnuts in the bumper instead of the lip since it'll be an easier install but they should provide slotted rivnuts so it'll crush into a cross with a larger bite area.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260609_163947952
I ordered these from Amazon but if anyone wants to do this I'd suggest finding the shortest slotted ones in m6. The ones I bought are 28mm tall.
Once you get to the front of the bumper (black grill piece) there's not enough space to fit them, I had to insert them at an angle and half crush them to get enough space to fully seat them to the bumper.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260609_164210384
Lip is now secured for more thrashing. I added black silicone to fill in any gaps, it's really not bad but I still have the tube from redoing the canards so I figured why not before it completely hardens haha.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260609_192120117
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build PXL_20260609_192250587
Did the responsible thing and added some much needed rice to the car. "Sticker bombed" the little window to block some sun for when my daughter is in the car. 🤡
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1781038074000_R0000966
Sporky McGeuschky
Sporky
Central Texas
Mine's more of a "Beaver Bomb"...
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 20260609_171056
nojeebs
nojeebs
25 FL5
Custom titanium badge arrived from GT Autowerks. His turnaround was quick and he worked hard in getting the design I wanted perfect. I didn't want to mount the badge yet so it's not completely laying flat on the surface.
It's a traditional Japanese pattern called seigaiha. Repeating waves of the ocean.....basically to me it means this build will be an ongoing journey with ups and downs but nothing will diminish the impact of the memories made.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1781129131000_R0000973
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1781129221000_R0000977
Got my weekly migraine going so I'm going to take a sumatriptan and pass out. Peaceful ocean vibes ahead. 😴
nojeebs
nojeebs
25 FL5
Mounted the Cobb Access Port on the car with the optional Scosche MagicMount Pro. I originally wanted to use the Offroam mount but the cf overlay piece makes it too thick to mount properly. Oh well. I'll hold onto it for now since I might change it up down the road.
I ended up purchasing an unlimited tuning package from JST Performance. Wanted to get a baseline done before all the headwork and turbo upgrade goes on this weekend. I was messaging Brian on here and what he offered and explained to me sounded like the best path with my limited time to mess with the car on a day to day basis. I love the fact I can just log 3rd gear pulls and send him the data and they can update the maps. I'll still do a dyno session once EVERYTHING is on to get a really solid map for the car but man...just the baseline tune he sent me to use to log with was amazing. Car pulls so hard to near redline (6400~) stock turbo exhausted literally.
Well here's to hoping to a smooth install weekend.
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1781640477000_R0001008
Also redid the pin lineup...Crafty from Battlecraft making sure my photos are color correct with a color checker chart. 😅
11th Gen Honda Civic Kazuo_WFC 2025 Civic Type R build 1781669736000_R0001018
